Home > 998cc > what carb needle/setup for my 998 turbo?????
clubminiflip
Member #: 54
nr coventry
whats my starting point, i have a standard metty turbo carb, will i need to change the needle?
cheers all
You will need to custom make a needle.
I started with a BDD iirc. but it's the same as any other SU fueling, get a needle and set the idle then start filing.
clubminiflip
Member #: 54
nr coventry
this is the hard bt then *happy*
do you know what the standard metro turbo needle is?
BDD i'll make a note of that!
never done anything like filing a carb needle, heard & seen it but i'm a lil heavy handed with stuff like that!
if i use a colourtune & my basic knowledge to get the idle revv & mixture correct, i'm not sure where i'd go from that point really reguarding filing a needle, i'll get the yellow book out, i've seen an article regurding this before & cant remebr where! a how-to!
i'm nervous now! :S
There's an excellent write up on this site called polishing needles I think. Done by Turbo Tel?
Do the search thing man *wink*
clubminiflip
Member #: 54
nr coventry
found it bat, cheers bud, i'll have to take that bit slow, i buy some emery paper! or could i use 1000 or 1500 wetn dry!
quite an interesting little read that article too!
still cacking it for this part though!
Little at time, it's really hard to put some back on *wink*
Use 1000 W&D
Other than feel have you got a way to check the fuelling? i.e. lambda sensor and gauge?
RR might be your best option.
clubminiflip
Member #: 54
nr coventry
i have a lambda sensor, no gauge yet!
i can a rr session in before avon i'll do so! i'll get a gauge & i can get the starting point from there cant i
i was contemplating a luminition AFR gauge that was on ebay! it wired into the lambda
Are you using MS or MJ?
not sure if the MJ has lambda input. MS does so you can use a laptop rather than a gauge.
But yes that's all you need. If you do a good job, you should just need the RR for a confidence check and a banana figure.
If you ask nicely, someone on the forum, close to you, might pop over for an evening to give you some pointers.
