Home > Beginners Tech > turbo carb parts
picky_88
Member #: 1780
hi there
new to the forum, I am currently working on a supercharged morris minor project. I am using the metro turbo carb, but mine has the plastic float missing. I cant seem to find a replacement part, only the one for the standard HIF carb. is the float the same for the turbo and non turbo versions?
thanks,
Picky_88
i believe so yes
I believe that the turbo float is foam filled to stop it being crushed under pressure. Try either Burlen or Avonbar for a new float. You may need to phone them & have a chat as opposed to just looking at their websites.
really? I know thats the common practice on other turbo carbs setups, but i dont think SUs bother with it...
they definatly dont seem to stock them at burlen anyway:
http://www.burlen.co.uk/sidelinkSearch.aspx?sideLinkID=46
if im wrong, apologies.
Joe
It would appear that I stand corrected.
http://www.burlen.co.uk/partlist.aspx?carID=10656
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Foam filled floats, never knew that!....learn something new everyday. :)
On 19th Jan, 2010 wil_h said:
picky_88
Member #: 1780
thanks for all the replies,
if you look on the burlen website the part number for a float for a turbo and a non turbo carb, the part number is the same. maybe a good idea to call them instead. but ive been assured that I really need a foam filled float, i dont want it to run lean under boost!
I think you only need a foam filled one if it's made of brass like a weber.
You'll need some serious pressure to deform the HIF plastic float!
picky_88
Member #: 1780
cant seem to find any foam filled floats for this carb... ive taken one out of a non turbo carb I had lying around and it doesnt squash easily (you can deform it slightly if you squeeze it really hard with your fingers) Also been thinking about the theory, if the float gets so squashed that it no longer floats, then it will sink and I will get overfuelling, which is much less of a problem than the mixture leaning out.
picky_88
Member #: 1780
phoned burlen fuel systems today float for the su carb turbo and non turbo exactly the same part.
