| Home > General Chat > Did one of those mensa tests... | |||||||
17th Jun, 2007 at 03:50:24pm
did ok, but one of the questions was:
17th Jun, 2007 at 04:01:55pm
Arn't you supposed to be able to float a pine needle on water to make a compass? On 28th Aug, 2011 Kean said:
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
17th Jun, 2007 at 04:19:07pm
That must be a trick question, as I think there may be either more than one, or none exist.
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
17th Jun, 2007 at 04:22:14pm
well its not me, im no magnet
Edited by Nic on 17th Jun, 2007. |
17th Jun, 2007 at 04:30:50pm
17th Jun, 2007 at 04:34:36pm
ooh yeah, dont cheques use a magnetic ink for the numbers along the bottom? |
17th Jun, 2007 at 04:37:03pm
They do. It's so that machines can read the info on the cheque. Those machines that are in abns and stuff that you can pay money in to instead of speak to cashiers. |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
17th Jun, 2007 at 05:13:48pm
but those inks contain iron that is magnetic and metallic. it might be referring to rubber or rather latex (bring it on nic) which can be statically charged to induce allignment of the electrons causing a magnetic effect. thats all the a level physics i know. lol
eu gosto de mamas = i like boobs |
17th Jun, 2007 at 06:41:41pm
17th Jun, 2007 at 09:01:26pm
this is completely random and i know nothing about it, but......
17th Jun, 2007 at 09:07:40pm
How about Mercury?
17th Jun, 2007 at 09:09:55pm
Graphite? Well maybe that's just a conductor, I can't remember. On 7th Nov, 2008 Nic said:
17th Jun, 2007 at 10:18:47pm
lol at mini13
17th Jun, 2007 at 10:44:56pm
Are you sure obout mercury being non magnetic?
17th Jun, 2007 at 10:56:27pm
yeh but thats electromagnetism which must be induced through a magnetic material in the first place - so its a wave rather than a substance - unless you want to be really clever and start with wave partical duality On 23rd Oct, 2009 sim_ou_nao said:
17th Jun, 2007 at 10:59:54pm
Lodestone??? or magnetite??
17th Jun, 2007 at 11:04:38pm
Fe3O4 though so it is metallic - contains iron On 23rd Oct, 2009 sim_ou_nao said:
17th Jun, 2007 at 11:06:37pm
Magnetic, as i understand it is something which is attracted by a magnet ie an iron nail is magnetic.
17th Jun, 2007 at 11:19:14pm
thats due to the electrons being fired throught the cathode ray tube (crt) or if it is the lcd type then they contain metallic compounds which allign with the magnetic field On 23rd Oct, 2009 sim_ou_nao said:
17th Jun, 2007 at 11:22:37pm
17th Jun, 2007 at 11:23:07pm
So if it's not an LCD type screen is that the answer to joey's question?
17th Jun, 2007 at 11:25:07pm
Please explain how O2 is magnetic
17th Jun, 2007 at 11:26:22pm
elements can be magnetic if they have unpaired electrons - such as oxygen.
17th Jun, 2007 at 11:32:05pm
There are 16 or so items that qualify under the paramagnetisim definition so why Oxygen? If you do a Wiki on Mercury you will find it's magnetic too.
Edited by danboy on 17th Jun, 2007. |
17th Jun, 2007 at 11:39:57pm
The electron beam is using a wave partical duality meaning that the electrons emitted are a wave upon impact with glass and then due to the refractive index of the material become particles again - but they are sub atomic and as such not a material but a substance - supposedly there is a scientific difference between the two but i never fully understood. ok so if you follow curies law it states that any material can be magnetic if it has free electrons so theoretically any compound that you make as long as it has free electrons will be paramagnetic. mercury is a metal and as such is not answering the question. I chose oxygen because out of that list it is the ONLY non-metal and i didnt want to start doing electron balancing equations to formulate an everyday compound when the simple answer is O2 Edited by stefaz on 17th Jun, 2007. On 23rd Oct, 2009 sim_ou_nao said:
