Home > Help Needed / General Tech Chat > Flywheel Problem?
A chap i know gave me this flywheel which had spun on the crank and made a bit of a mess as you can see from the pics. My G Friends dad whos a tool maker re cut the taper but there is still some slight damage, do you guys think it will be ok to fit still or is it beyond it. I have put the flywheel on and torqued it and i cant turn it!
Thoughts, Oppinions welcome.
Mike
no mate dont risk it, about 3 years ago i took the chance with a flywheel in almost identicle condition, 50 miles later it was new crank time.
theyre only 90 quid, just not worth chancing imo
I thought as much tbh, I have a 6581 Crank in mint condition as well and i dont want to destroy it! Looks like im buying a new one then!
can be usable with a verto centre bolted in,
I was going to suggest that. Have Carl fix it for you!
clubminiflip
Member #: 54
nr coventry
do you mean the verto crank end bolt & the key thing that located on the crank fastcarl?
the ultralight flywheel i have is'nt as bad as your flywheel 1573wx & i've lapped it onto my crank & all seems well, its gotta go in the car yet though :/ i'm feeling confident it'll be ok though! i'm using the pre-verto keyway but i have heard of using the very type!
cant flywheels be refurbed/recut/sleeved&recut when they get pitted or damaged etc etc
Could you sort that carl?
Dangerous
Member #: 417
I think he means machining a big hole in the middle of the flywheel and bolting the centre part of a verto one in
clubminiflip
Member #: 54
nr coventry
sounds a good shout either way to me!!!
i know £100 is'nt bad for a new flywheel but its a bit of a shame that there are lots of uprated/lightened flywheels around that are scrap cause of the crankhole being knackered!
a refurb on these would surely make some coins if it can be done cheap enough!
Edited by clubminiflip on 18th Jun, 2007.
Exactly. Its £100 i can save or spend in other areas.
On 17th of Jun, 2007 at 11:04pm clubminiflip said:
sounds a good shut either way to me!!!
i can, and the going rate for such a task willb e £50.00 inc a perfect used verto centre.
not quite the £100 saved but hey!!!
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Forget the flywheel, where do you get G friends from that have handy dads that can machine things for you?
On 7th Nov, 2008 Nic said:
naeJ
m
Put my name down for one of those too!
