Home > Help Needed / General Tech Chat > lower CR
beestje007
Member #: 1230
hello there, whats the easiest way to lower CR?
i want to turbo a 998 and it has to produce around 90 HP...
thanks
In your case use a 295 head.
Or open out the chambers in the one you have ...
beestje007
Member #: 1230
i'm sorry but i'm from belgium and my english isnt that good to undrstand "open out the chambers"? what do u mean with 295 head... thanks alot Bat
beestje007
Member #: 1230
beestje007
Member #: 1230
double post sorry
beestje007
Member #: 1230
i finally bought a metro NA 1275 engine, and i'm going to turbo it, i only need like a 100HP. so do i only have t0 lower CR like 8.0:1 and replace it with turbo pistons and make the chambers from the head bigger? can i keep my original Cam? thanks
You won't need a compression ratio anywhere near as low as 8.0-1 to achieve 100hp. Just to give you an idea, the stock Metro Turbo had 9.4-1, ran 7psi and had 94hp.
The easiest and cheapest way to lower the compression, should you need to, is to enlargen the chambers in the cylinder head.
Phil.
Basically you remove the beak out of the head
your looking for 28cc in the combustion chamber
while you have it stripped you are better to change the mild cam to say a kent 266 cam or a swift tune SW5 cam
hope this helps!
Oh, you can use the stock cam, if you want, though an uprated one, such as the Avonbar Phase 2 would be much nicer. Stock pistons should be ok in a low boost application.
beestje007
Member #: 1230
thanks alot benross and turbo phil, so i can keep my original pistons and maybe but not nessasary another cam. And what about the gearbox?
chinlesswonder
Member #: 1192
In the garage......again!!
uprated diff pin and overhaul the gearbox. should hold up to 100bhp with good standard parts
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
beestje007
Member #: 1230
thanks chinlesswonder
beestje007
Member #: 1230
a little question about the brake lines, i'm restoring my mini completly, its almost completely naked now, almost bare cage, and i was wondering where to buy new brake lines, can i buy them from avonbar?
beestje007
Member #: 1230
chinlesswonder
Member #: 1192
some good deals on ebay for front and rear subby lines. hardest one is the line running from front to back, bit of a bugger to get straight when it comes coiled up, if yours is in good condition, clean it and reuse it
beestje007
Member #: 1230
thanks
