Home > Help Needed / General Tech Chat > Studs for thermostat housing when you remove spacer?
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
I decided to get rid of the spacer on my turbo engine as i will be drilling a heater take of on the other side of the block.
However the old studs were fookd so i decided touse the shorter studs from a normal mini one but they dont seem long enough. What studs do i need when i use just the metro housing without the spacer?
Any help would be much appreciated.
Cheers.
James.
chinlesswonder
Member #: 1192
In the garage......again!!
5/16 unc bolts?
Edited by chinlesswonder on 25th Jun, 2007.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
hammoj28turbo
Member #: 1502
Not sure. Could see. Anyone else have any idea?
Mine's got bolts in.
daniel_johno
Member #: 751
Aberdeen
yeah its 5/16 unc.
I got long 5/16 unc bolts from work then cut them to length and used them.
If you do use bolts and cut them down put a nut on first and it will retap the start of the thread when you remove it.
Daniel
hammoj28turbo
Member #: 1502
Ah, nice one. Cheers guys. Will do that.
buy some stainless cap heads off ebay, £2 and jobs done.
