Home > Technical Chat > straight thru exhausts
Lone Wolf
Member #: 1092
Yours from the Funny Farm
will a turbo engine benefit from having a straight thru exhaust?
i wouldnt think so due to the backpressure needed beeing created by the turbo
i know about the legalities BTW
ta
tom
Warning:Stig in Training
The Turbocharger:God's Finest Minute
The less backpressure in the ehuast the better for a turbo engine.
With no back pressure in the exhaust the gases exit the turbo easier meaning less backpressure at the turbo.
It also lowers turbo temperture too.
Lone Wolf
Member #: 1092
so in a word yes. right bat?
Badger
Member #: 1488
Basically any exhaust with a minimum of back pressure. So yes.
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
JT
Member #: 637
Hertfordshire
im going to try and make a exhust so its 2.5" from the turbo outlet to the tail pipe with a single back box on it.
not sure if theres a system for a mini already that size? i might just get maniflow or somwere similar to make me up a back box and just make the rest up myself.
the only thing that will be a proplem that i can see is getting it past the subframe, might have to oval the pipe in that area or somthing.
cheers
josh
My build thread..
The problem will be getting it in the tunnel past the remote *wink*
I have been looking at doing a 2.5" system, with a rod change box it shouldn't be to much of an issue as you can always move the gearchange inside to give more room, and move the engine forward a tad, but with my remote box and full length works style sumpguard its just not practical...
The problem you will have is getting it past the pot joint, you will need to oval the pipe to get it to clear (there is about 2.25" beteen my spicer joint and the subby), and its possible the boot might not like heat that close to it so a change to spicers might be a good idea.
for 2.5" bits 16v minis are worth a look, they do a 2.5" stainless rear box (not cheap tho!) and 2.5" bends and stuff.
JT
Member #: 637
Hertfordshire
cheers for that mini13
i may just put the gear selector in the car, havent looked into it proply yet but i know theres a long thread on here about it!
do you think it will be worth the work to cange it from 2" maniflow to custom 2.5"? i supose it would make it breathe better and spool up sooner?
cheers
josh
My build thread..
What size it the outlet on the turbo?
I can't see any advantage to having an exhaust bigger than that.
Lone Wolf
Member #: 1092
thanks
so to elaborate how do you bend exhaust pipe without a pipe bender?
i heard something about filling it with sand once but not sure how that works
I was under the impression that if you made the exhaust too big it would cause turbulence slowing the gasses down & increasing back pressure.
Don't want to sound negative but I'd suggest you consider whether you need a 2.5 exhaust.
Someone please correct me if I'm wrong.
I don't know if that's applicable to turbos Rob, but I'm no expert!
Either way, bigger than the turbo outlet isn't going to give any advantage.
JT
Member #: 637
Hertfordshire
so basicly the ideal size exhust for a turbo moter is whatever the turbo out let is?
My build thread..
It is recommended that there is still some backpressure in a turbo exhaust system. This is because of the way the oilseals work in the turbine. Too little back pressure and you risk the seals leaking.
Look at Benross'ssss exhaust. It seems a reasonable compromise, 2" til past the selector then amassive after that (2.5" or 3", not sure).
I have a 2" all the way, it fell off at the elbow once when racing, and there was no noticable differance in power (or noise as it happens).
Scruffy
Member #: 328
Seaford Rise, South Australia
You will need some form of silencer if you ever want to take it to Combe!
On 5th Sep, 2011 Vegard said:
johnK
Member #: 690
Norfolk
This is the one on my gold car - the main tube is 2 inch inside dia from manifold back to the silencer - the silencer is circa 60mm bore. The silencer is Ti and weighs 1kg - the rest of the system is thin wall T304 and weighs 2.5kg - so all in 3.5kg - not surprisingly it sounds like a big superbike!lol! - but not excessive or chav like by any means.
JK
If Carling made Mini engines
You've got 1/2 a bike engine, so why not a bike exhaust *wink*
Nice undertray John, mine is a bit more extreem as the exhaust is on the boot side of it. Made a massive differance to speed and stability at speed.
As for the scilencer, looks a similar size to mine, but mine is steel and DOES NOT weight 1kg, it weighs a shit load more.
This pic was taken a while ago but heres my pipe! Its a straight Stainless all way to front down pipe. Im going to have to see wether its gunna be too loud yet!
Edited by MikeRace on 3rd Jul, 2007.
johnK
Member #: 690
Norfolk
yip - that one may burble just a little!
Will - thanks it is quite important to the dynamics of the cars to flush the rear floor area off - especially running beam style axles. When I first built the car in 96 it ran for a year without the tray but was very oversteery/ unstable at high speeds, lift off situations - 97 saw the tray go on and it really does keep the rear on the floor at high speeds
JK
dn89mini
Member #: 1506
Cheshire
Does anyone sell an undertray like that?
Check out the (slow) progress at.......
http://www.turbominis.co.uk/dn89mini
Badger
Member #: 1488
Aye, also interested in the rear tray... heard about them but never really seen one before. Looks easy enough to make, but I'm sure I'm wrong lol *happy*
You'll have to make your own I'm afraid boys. Big sheet of alloy, bent to shape thwn rivited to the subframe.
mikemph
Member #: 449
Oxford
Don't spose you have some more pictures? so I could knock up one at work.
Turbo Shed
Member #: 30
Epsom, Surrey
i think i will make one as well.
where did i leave the cardboard and sticky backed plastic?
