Home > Help Needed / General Tech Chat > hi-lo's stuck to the cones????? what do i do arrrrrhhh nightmare!
clubminiflip
Member #: 54
nr coventry
i have some genuine ripspeed hilo's in good condition with the key & everything trouble is they're stuck to the rubber cones, i'd obviously prefer to keep both in working order, how can i make them part company????????? well annoyed!
i've gave them a bash with a dead blow hammer with no joy! poked a screwdriver, no good! i'm really not sure what to do at all
Edited by clubminiflip on 2nd Jul, 2007.
Get a bit of penetrating oil in there, then just keep bashing.
You might need a bigger hammer or bigger screwdriver, but you are doing the right thing, just keep going.
Nick
Member #: 154
Midlands
yup, brute force and ignorance is about the only way to get em apart.
clubminiflip
Member #: 54
nr coventry
i have cut callas's hard skin bits, on my hands frm wacking them! & my forearms are all pumped up i cant grip, i hate probs like this they are just arsey!
i spose my worst case situ would be to bugger the rubber donuts up
i was mulling over dropping them in boiling oil, or pouring it on the joint
clubminiflip
Member #: 54
nr coventry
jamesfawcett
Member #: 218
Bingley, West Yorkshire
mine were like that, stuck fast would not come off. Boiling water in a washing up bowl made them come off.
If you've got a long bolt the fits the rubber cones(like the one for the compressor tool), screw that in and it should lift the cone off *wink*
Of course heat and WD40 not hurt either :)
clubminiflip
Member #: 54
nr coventry
the cones & hi-los are out of the car already bat! lol! buggers wont come apart! tried boiling water & thats not touched them feebs :/
thinkin about it if i drilled a hole in the workbench & compressed them against that it may help to get the wd40 in, or a decen Wack! with the deadblow mallet!
stefaz
Member #: 1656
stoke-on-trent
is this the front or back? might be worth throwwing them about or beating them against concrete steps
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Funny you should say that! I was doing the same thing yesterday, got pissed off with one and lobbed it, hit the old front subframe square on and came right apart lol!
Come round mine clubmanflip, ill piss you off and you can throw it at my old subframe if you want?
Rich
clubminiflip
Member #: 54
nr coventry
rich lol *happy* they are a front-set, i bet the alloy of the hilo & steel of the donut has corroded together a bit, or some paint has dribbled between the 2, i've never known such a pig of a prob! its pissin me off more than my other mini greviances hehe
I meant to do it off the car. Just use the bolt out of the middle not the whole compressor tool *wink*
As you screw the bolt through the cone it will push againest the bog bolt in the Hi-Lo and force the two apart....
wd40, or if you get stuck squash the cone in a vice on the sides and give the hi lo a bashing with the rubber mallet
If there both in good condition....do you need to take them apart?
give them some Bongo!
