| Home > Help Needed / General Tech Chat > Shear bolt!! | |||||||
4th Jul, 2007 at 06:04:31pm
Theres a couple of shear bolts holding on various bits around the steering column/pedal box area.
4th Jul, 2007 at 06:14:53pm
yes its a captive nut if its the one i'm thinking off. try the end with the sheared off bit. usually some good pliers or put a nick in it usually helps.
4th Jul, 2007 at 06:26:06pm
or use a chisel to "tap" it undone On 28th Aug, 2011 Kean said:
4th Jul, 2007 at 06:34:24pm
I did mine and it was a right ballache, i ended up using a dremel to cut off the domed head, took about an hour lying on my back for the both of em. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
4th Jul, 2007 at 10:16:28pm
5th Jul, 2007 at 03:00:30pm
These bolts are one of the few places that easy-outs are useful as they just need 'cracking' usually.
