Home > Help Needed / General Tech Chat > MJLJ tacho
steve1275
Member #: 951
Bromsgrove
I need a tacho to go with mjlj tacho output.Reading the archive left me confused because I know very little about the different specs of Mini.Can anyone advise what spec of mini tacho would accept the mjlj output?
'Where does the engine go?'
Kean
Member #: 341
aka T2clubby
South Staffs
You can use any standard tacho if you take the signal from the edis unit, its wire 11 on the edis plug, it may be blanked off, but you can drill the plug and fit the extra cable to pick up the pin on the edis..............
If that makes sense lol
That's what I did with mine, as I found that the tacho output on MJLJ didn't work with the late Rover 3 clock dash I've got fitted.
I did the same, unfortunately It didn't work as I have a tim gauge. :(
I just wired some shift lights in instead...*tongue*
colas
Member #: 102
Pennsylvania USA
I went the shift light route as well.
i just stuck mine on the pip line from the edis to the mj ,worked well.
If you can get hold of a Mpi rev counter (assuming you're using the standard 3 clocks) and can just connect it to 1 coil negative.
The other option is the 2 diodes setup, I'll try to dig out the picture later.
Edited by Bat on 7th Jul, 2007.
T3Tone
Member #: 252
Sunny suffolk
Just for reference i got a Cheap TIM tacho working with megajolt using the diode circuit.
-MINI CLUBMAN 1380 TURBO-
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Just digging this up to see if anyone has any ideas how to get my trusty Tim tacho going with MJ? Silly question, but can I not just take a signal off the wire to the coil pack or would this be the same as the PIP wire? I know it's wasted spark so the reading will be wrong but there is a 2-4-6 cylinder switch on the back of the tacho. Just a stab in the dark, I miss having a tacho!
On 7th Nov, 2008 Nic said:
naeJ
m
Si P
Member #: 912
North Yorkshire
This link might help. It got mine working.
http://www.autosportlabs.org/viewtopic.php...highlight=#8386
Si
Jay#2
Member #: 648
Thanks! That helps, I don't think that the Tim is an RVI but I will need to look into this.
naeJ
m
philc
Member #: 1346
bromsgrove
i use number 11 of the mj, for both dash and tacho, works fine for me
Gibbo
Member #: 34
Can combine the signals to the coil pack with 2 diodes.
This is what I have done.
Look half way down.
http://www.autosportlabs.net/MJLJ_V3_vehic..._kickback_pulse
t3gav
Member #: 229
Gavin@minispares.com
kent
How did you wire the shift lights Matty? Guessing there is no need to buy the shift light kit...
