Home > Help Needed / General Tech Chat > Setting Tappet Clearance
This is a slightly stupid question, but is best to set the clearances when the engine is cold, or up to temp?
Ive been thinking about it today and thought of merits for both
Engine Warm1 Votes 1 Votes - 0%
Engine Cold14 Votes 14 Votes - 0%
engine cold,
the settings should be more repeatable as the push rods will be at... what 20 deg +/- 10 deg rather than 100 deg +/- ???? deg
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I've always done them cold inc ford crossflows etc.
On 19th Jan, 2010 wil_h said:
if its hot subtract 0.002"
cold is best, you dont get hot fingers
Dangerous
Member #: 417
Cold or not been driven for a few hours temp here
cool (err no pun intended)
Ill check them now then, i started thinking and then just confused myself
And then with the application of some alcohol i remembered that the plate on the morris minor says to set them cold
For most of us the application of alcohol usually leads to an inability to look women in the face when speaking to them, and a yearning for a kebab.
Nic starts thinking of Morris Minors.
Strange boy.........
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Theres a connection between kebabs & women around here. Both look like road kill!
You need to find a better Kebab shop *wink*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I perfer to do it with the engine running.....
:p
AlexF
Turbo Shed
Member #: 30
Epsom, Surrey
i'm with Alex. check them with the engine runing and set them to the thickness of a screw driver blade. must be a flat head.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I would love a reply where someone has tried this and managed to get a good thick screwdriver in between and thus making contact between the piston and valve :)
Turbo Shed
Member #: 30
Epsom, Surrey
yes but with the engine running i would like to watch you try and get the screw driver in!! may be hold the valve open with your fingers!!!
On 9th of Jul, 2007 at 12:53pm Turbo Shed said:
i'm with Alex.
Didn't know you where like that! LOL
Turbo Shed
Member #: 30
Epsom, Surrey
almost as good as a person i know who works for the AA, checked a cambelt tension with the engine runing by putting his finger between the belt and pulley. i think the belt was a bit tight as it took his finger off!!!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
i'm with Alex.
What ARE you insinuating!
Alex
AlexF
