Home > Help Needed / General Tech Chat > Flywheel
Zeemax Power
Member #: 393
Oulton Park
Wondering if you can put a 1275 flywheel on a 998 and will it run?
Also the 998 in the older type clutch set up, so would it make anydiff putting the later type on?
I put a 1275 flywheel on, and the later clutch set up on, an older engine.Wondered if the chank was different cos when you start it makes a grinding noise, and the start motor is like solid to get out!
cheers
http://www.Zeemax.com
You need to keep the same starterv motor to the same flywheel.
998 starter with 998 flywheel
1275 starter with 1275 flywheel*wink*
Failing that you need to start fitting new ring gears *surprised*
clubminiflip
Member #: 54
nr coventry
bat you have me stressing now, i dont know if my flywheel ring gear is 998 or 1275 type arrrrrrrrh!!! i have the correct starter motor
seemed to mesh ok on the bench chking mine out
xcuse my thread hi-jack zeemax!!!!!!!!!!!
It's not so much the case of 998 or 1275. It's verto and pre verto.
If you have a pre-verto flywheel you need an inertia starter (just a big round drum)
If you have a verto clutch you need a pre engauged starter ( smaller body, with a piggy back solenoid ON the starter)
Otherwise as I said above, you'll need to fit a new ring gear *surprised*
Zeemax Power
Member #: 393
Oulton Park
same ring gear for the clutch or the engine, or the one that come off?
Ring gear has to match the starter, nothing else :)
AL
Member #: 1347
Croydon (South London)
If your not sure which starter to use count the teeth on the ring gear. From what ive found 107 teeth means inertia starter 129 means pre engaged starter.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
if you change ring gear you should also balance the flywheel
Zeemax Power
Member #: 393
Oulton Park
if you change the ring gear what effect does it have on the other gears do they need to be changed or will you get away with it
stefaz
Member #: 1656
stoke-on-trent
its not in the actual gearbox mate - its just to mate it with the starter motor
turbo hogster
Member #: 178
stowmaket suffolk
verto comes in either pre engaged or inetia, later typeswere usaly pre engaged.
easiest way to tell is pre flywheel teth are straight across weres inteia are angled
Zeemax Power
Member #: 393
Oulton Park
everything seems ok apart from undoing the nut on the end of the clutch and crank that was so so tight for edges!
everything looks the same problem it looks like the starter is just getting on the end of the teeth and not push far enough across?? any ideas
