| Home > Help Needed / General Tech Chat > O/T Audi diesel | |||||||
10th Jul, 2007 at 02:52:37pm
driving home last night, the oil warning light came on. Stopped, checked levels - topped up a bit to be on the safe side. Carried on and it came back on again.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
10th Jul, 2007 at 03:30:03pm
sounds like a dodgy switch to me. Get vag-com on it, that will tell you for sure. |
10th Jul, 2007 at 04:45:13pm
Yep sounds like a dodgy sensor to me, what comes up on the dash display?
10th Jul, 2007 at 07:05:15pm
Cheers guys.
10th Jul, 2007 at 09:28:46pm
you paid £73 quid for oil? no longer a series, but still 1.3 turbo.
10th Jul, 2007 at 09:35:38pm
Hi,.
11th Jul, 2007 at 09:03:31am
On 10th of Jul, 2007 at 07:05pm Rob Gavin said:
I've got the DIS display - all is does is flash a big red oil can at me with lots of bleeping! Ah, mine did that to me once, I thought it was oil pressure not level, so turned it off immediately! Thinking about it I had just hurled it round a roundabout so the oil must have gone to the other side of the sump.
11th Jul, 2007 at 02:34:31pm
well took out the sensor last night and cleaned it up a bit. The wiring is caked in oil from a leak from the rocker cover so have cleaned that up as well.
11th Jul, 2007 at 04:04:12pm
Ahhh, rocker covers leaking oil, been there done that, heres a tip, get the gaskets from Audi, they are cheaper than the motorfactors were.
11th Jul, 2007 at 05:19:42pm
cheers Tom.
11th Jul, 2007 at 05:37:04pm
Whilst saying the oil switch is faulty....it might be wise to actually check you have oil pressure !!!!
11th Jul, 2007 at 06:05:17pm
He writes above that there is a different light for low oil pressure, the light that has come on was only for low level |
11th Jul, 2007 at 06:45:58pm
Stevie is spot on with the crankcase breather filter issue, there is a thread by me about this only the other day, my car started smoking terribly, a new breather filter at £40 cured it and also the oil leaks it has are much reduced (although not gone).
Edited by Tom Fenton on 11th Jul, 2007.
11th Jul, 2007 at 08:12:28pm
On 11th of Jul, 2007 at 06:05pm miniminor63 said:
He writes above that there is a different light for low oil pressure, the light that has come on was only for low level oops...missed that bit :) 9.85 @ 145mph
11th Jul, 2007 at 09:36:26pm
Cheers guys. I think I'll change the breather out of courtesy anyway.
11th Jul, 2007 at 09:59:54pm
11th Jul, 2007 at 10:30:01pm
Have fun with the breather, its really awkward to get it out!!!
