| Home > Help Needed / General Tech Chat > Megajolt queries, almost there though! | |||||||
13th Jul, 2007 at 10:23:47pm
I have nice fat white spark but alas I don't think I'm getting it at the right time. I have the VR sensor positioned at 8 o'clock the missing tooth is at TDC. I have some ball park values in the map but it won't start, it's slows rhythmically when I turn it over and it coughs out the carb. I have a series of questions/concerns as follows:
On 7th Nov, 2008 Nic said:
13th Jul, 2007 at 10:39:59pm
At a guess I'd say you're about 30 degrees retarded, as the VC sensor should be at 9 o'clock when the missing tooth is at TDC. Isambard Kingdom Brunel said:
13th Jul, 2007 at 11:32:25pm
Ah right, I was looking at it the wrong way. I take it I can adjust for the VR position by adding 30 degrees to all the bins?
14th Jul, 2007 at 12:39:47am
i dont think the rev counter on the software moves till you get over 400 rpm or something like that
14th Jul, 2007 at 09:49:51am
14th Jul, 2007 at 10:35:41am
On 14th of Jul, 2007 at 12:39am Nic said:
i dont think the rev counter on the software moves till you get over 400 rpm or something like that Ah, that's what I wanted to hear. I don't think I'm getting near 400rpm under cranking with the flatish battery. That's that settled! My bracket is like wil_h's bracket (in the pic), not quite 9 o'clock but almost. Can I compensate for sensor position with the software or should I remake a better braket? The coil pack is marked 1 2 3 4 and I have the leads plumbed in 1 to 1, 2 to 2 etc. But to me the coughing out the carb is more like lead mix up than the timing being out. If my sensor is at 8ish rather than 9 would I be over advanced or retarded? Thanks.
14th Jul, 2007 at 11:43:56am
14th Jul, 2007 at 12:59:39pm
Ah, don't panic. It's all sorted now. I put the lead from "1" on the coil pack to cylinder number 3 and vice versa, and the lead from "2" to number 4 and it fired straight up! Ticking over nice and smooth. Just fixing a few water leaks then I will start fine tuning my map. Thanks for all your help! On 7th Nov, 2008 Nic said:
14th Jul, 2007 at 01:08:34pm
14th Jul, 2007 at 02:44:22pm
Yeah your right! But when I wired it all up it was pretty easy as the coil pack and EDIS came with all the original wiring. When I wried the +ve and -ve for the coil pack I just went by the colour of the tails on the EDIS and matched that with the tails on the coil pack. It doesn't make sence but I don't care it works! Time for a quick spin! On 7th Nov, 2008 Nic said:
