Home > Help Needed / General Tech Chat > Gear Linkage
Mark1275GT
Member #: 886
London.
Do i only need to get the Grub pin out to get the Gear Linkage off. (at the box end) If so, any tips on how to get it off..
The MG manual dont tell me as such.. ?
Cheers :)
Select reverse gear and it will give you a better angle to get a punch onto it. *wink*
You'll need to undo the other link that goes to the gear stick aswell.
the grub pin for the bottom rod,
the rod above it there is an obvious bolt.
put it in gear (can never remember which one!) and tap it out with a flat ended punch.
I hate these pins so much I put a bolt through with a nylock on the end, M6 i think.
Mark1275GT
Member #: 886
London.
U sure i have to undo the other link that goes to the gear stick as well ?
im only taking the engine out.
i thought it will just come out from the gearbox end..
If so, how do i do that..
Could i drill the Grub pin out ?
Cheers :)
both rods need to be disconnected from the gearbox,
the pin could be tricky to drill as its hollow, split down one side and springy.
I wouldn't try drilling as you are very likely to break the drill off as it would catch on the slot in the roll pin.
If its stuck then it would be best to get a bit of heat on it than drill.
Oh yeah, make sure you use a punch big enough, if its too small it will start to go through the centre of the roll pin and make it an even tighter fit. *wink*
Its fairly easy to drift out.
I use a quality tool, a ground off 4" nail! lol! works every time.
*smiley*
Mark1275GT
Member #: 886
London.
Got it off :)
Put it into reverse, Which gave me more room to bash it out..
Thanks alot :)
On 17th of Jul, 2007 at 06:09pm Mark1275GT said:
Got it off :)
Thanks alot :)
PMSL sigged. *laughing*
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
I too am thinking of doing this as mines apart at the moment! Didnt know if it was a good idea or not as there is a little bit of play and i wasnt too sure if it was a bodge or not!
Would you reccomend using a bolt and nylock then? I have it ready on the collar already, death to the heathen roll pins i say!
Rich
Edited by richminiturbo. on 17th Jul, 2007.
M6 and nyloc is a BODGE. Use the proper roll pin, and spend a couple of quid on a proper punch, then you will have no problems.
Nick
Member #: 154
Midlands
lol, i've had an M5 with a nyloc through mine for years now, just replace it every time the engine comes out :)
Me too with the bolt, no nut *surprised*, but the bolt is looking very worn nowadays. It's been in there for a few years....
Rough bastards!
lol a bolt through the gearlinkage is the least of my concerns on my daily driver....
