Home > General Chat > nervy day my 1st full engine build, top to bottom, its started! :S
clubminiflip
Member #: 54
nr coventry
hi chaps, well i've started my 998 turbo engine build this evening!
cleaned the block "again" & my components &................
i have fitted my crank & main caps so far, all with the help of my trusty haynes manual & tips from you chaps in my head!
had a an issue with my centre main strap, the grooves were'nt deep enough & caused the crank to bind on the thrusts a lil-bit, i filed the grooves & cleaned the strap again, fitted it & with all the caps torqued to 63lbs the crank is running super smooth & i cant identify any tightness or play whilst turning it so i'm a happy chap so far, i'm just gonna chk the end flloat now!
i forgot to tell ya's "i think" i put a light beveled edge on all edges of the inside block too in the same fashion as the vauxhall xe turbo chaps do with their blocks
i have pics & i'll pop them up too later on
nerve-racking stuff for a novice but slow n steady is my saying for this! confidence is still high pheeeeeeeeeeeew!
Edited by clubminiflip on 18th Jul, 2007.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Congratulations m8,
You are the new Benross *wink*
Nice work chap, jobs a good'n'
On 19th Jan, 2010 wil_h said:
Nice one pal. Its fairly straight foward. Just be methodical and clean and " tha shud be reyt cock"
clubminiflip
Member #: 54
nr coventry
cheers peeps, all's going swimmingly untill now!
got to the poont of putting my belt drive on & i've forgot to nip to minispares for new seals for it have'nt i, what an "arse"
cam & followers have been soaked in cam lube too,
the gasket under the engine plate was a really good fit unlike some gaskets i've changed before! just gonna have a look at the fit of the oil pump gasket & come in for well earn foon n a bath
i'm not a logical thinker at all, logic games i have no time for but this is like technics lego aint it, wish i bit the bullit years ago to build my own motor!
if this engine runs i'll be pretty chuffed to say the least, i feel its going to smooth! lets hope it stays that way, my short block is nearly there within 4 hours! once the short engine is in one piece i'll go over it before adding other bits
i feel some magners will be bought by me 2moz *happy*
woop woop! *tongue*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
nice drop of cider! Was thinking of doing magners ice lollies for those hot summer days!
clubminiflip
Member #: 54
nr coventry
oh are! good call, i've done vodka melons & jellie-babies before *happy*
i'm cc-ing my head at the mo, i only have a syringe & i really need a burrette i think its called, one of those thinks you use in chemistry! the syringe ain to good to be honest! stciks alot, not much control with it!
clubminiflip
Member #: 54
nr coventry
i was just thinkin i i was half as competent as some of you at this engine building lark i'd be well chuffed! never mind the nxt benross :)
its a great feeling when its all going right, i was scared to death the first time i started up my first rebuild (a std 1275), good luck with the rest of the build!
stefaz
Member #: 1656
stoke-on-trent
goos luck with the rest mate - glad its going smoothly for you - il have to wait to see if mine fires up first time when i try next week ish
clubminiflip
Member #: 54
nr coventry
hopefully i'll run mine up nxt week if i get these seals for my belt drive, & dont get to confused doing the "timing" dreading that bit a lil but perserverance is key i spose
i'm gonna do my first startup on my dads van as it has no front end, so i'll just put fuel in a container & hook up a temopry rad!, fingers are crossed!
good luck to you too pal! hope alls going smooth for you too!
oil pressure gauge at the ready......arrrrhhhh cackin it
stefaz
Member #: 1656
stoke-on-trent
lol smooth certainly aint the word for it - found out the reason it wouldnt turn over today - the engine mount bolts fouled the flywheel - so hopefully i can finish the rest of the wiring in for next week and press go without more cockups lol. just be careful with a temp rad to not run it too long mate - air in system and all that.
Needs to run for 20 min at 2000rpm plus to bed in cam to followers, this is a MUST.
Brocky
Member #: 224
Katy TEXAS
Hey Tom,
Your good at writting procedures...*smiley*
Fancy doing a rebuilt engine starters guide ?
Priming oil, intial settings, run in times / milage, turbo charger precautions etc. *smiley*
Brocky
clubminiflip
Member #: 54
nr coventry
good call brocky *happy* i've been taking a few notes already, i've gone a lil scew on some but i'm basicly doing ok i reckon, probobly a bit stupid of me doing a 998 turbo build for a 1st ever engine build but i though bugger it!!!
in the deep end!
cheers mr f& brocky! alls going smooth still if all carrys on like this i'll try to get it drivable for MITP! I'M TEMPTING FATE SAYING THAT I KNOW!
Brocky
Member #: 224
Katy TEXAS
Nice one man,
My main piece of advice is to make sure the engine is fully up to temperature before you drive it or at least before you put your foot down...
also let the engine idle for a minute or to after stopping as the turbo can spin on.*smiley*
Brocky
clubminiflip
Member #: 54
nr coventry
cheers brocky! yep i'm mulling over the idea of a turbo timer, i had a toyota glanza turbo (same as the starlet) & it was a worthwhile mod on that, should be able to fit one to a mini with a relay i'd have thought, if not i'll defo let it cool slow by keeping it running
i'll be to nervous to floor it for a while i reckon, i'll defo take it easy for a while
JT
Member #: 637
Hertfordshire
my nighbers are going to love that!! lol
My build thread..
clubminiflip
Member #: 54
nr coventry
bugger the neighbors, a lads gott do what a lads gotta do *happy* my garage is a bt of a distance from the house so should be ok, garage door will be kep shut with a pipe from the zaust to outside, my neighbors are pretty good to be honest!
