Home > Show Us Yours! > new install
thasim82
Member #: 1413
any comments on this arrangement?
what think of home-made plenium chamber in-let and cooler pipes?
http://s187.photobucket.com/albums/x49/thasim82/
Carl
Member #: 95
liverpool-on-sea
intercooler pipes look ok. should work fine.
whys your dumpvalve signal pipe go inside the car?
thasim82
Member #: 1413
dumpvalve singal comes off a tee ( from top of in inlet) and other pipe goes off to boost gauge..
nice clubman btw.:cool:
Brocky
Member #: 224
Katy TEXAS
Looks good ,
I would consider a splash guard for air filter in the wet between the road wheel and filter if you are out in the rain or you will get a water injection you didnt order lol *smiley*
Ps I guess its a clubby front based on the intercooler position ??
Is that a 4wd cossy cooler ???*smiley*Should be good for lots of bananas *happy**happy*
Brocky
Edited by Brocky on 19th Jul, 2007.
thasim82
Member #: 1413
yeah thanks, i've got 'slabs' of thin rubber material to attach to brace bars somehow, sometime, somewhere.lol
its not a clubman-yet. i've got a grp roundnose fitted-with a rather large 'hole' in it.ooer
planning running 12psi. does anyone care to guess how many bananas and curlywurlys it'll muster?
oh and any good rr's in the highlands?
Brocky
Member #: 224
Katy TEXAS
If you tell us the cam and head spec....etc
Wallace Performance in Aberdeen, Dyce is the nearest one to me....
Brocky
thasim82
Member #: 1413
im not sure, i know the heads not std though as the chambers have been de-beaked, (made into a D shape if you know what i mean). std cam, pistons, and rockers though.
i got the engine second-hand in bits and fitted new mains, bigends, rings, chain, and followers. suppose should've done more research, but just cant wait*laughing*
Brocky
Member #: 224
Katy TEXAS
If you time it up for 98 ron fuel and about 10 - 12 psi of boost, with good timming you could expect between 120 - 140 bhp, but be sure the bottom end can take it......
As alex b says, unless you have upgrade the diff and drops you will have to be mechanically simpathetic.i.e not balls out 1st gear st offs....*smiley*
thasim82
Member #: 1413
hmm i know, std box on now, with 38thou miles already*oh well*
i'll be happy if it lasts a year, then i'll think about straight cut drops and x-pin diff.
what sort of box do you run?
Brocky
Member #: 224
Katy TEXAS
Rebuilt standard box but like I say, save the lead foot for 3rd and fourth.....*smiley*To be honest you will enjoy the torque with the cossy cooler more at high speeds anyway...*smiley**smiley*
MarkGTT
Member #: 1194
Shropshire.
looks a familiar design! :cool: good work so far.
im guessing the box wont last a year tho!
very nice
thasim82
Member #: 1413
ta.
I've been waiting over a week now, for two 50mm silicone elbows form the bay of th e! *angry*
had it running with the std plenium elbow, and since then decided to go for megajolt ignition! *happy*
just one question, where can i get a suitable map from for my engine setup? as im not confident in making my own
contact Alex F
thasim82
Member #: 1413
just bought trigger wheel, vr senor, edis module, coil pack, and screened cable from ebay. for the sum of 70 big ones. how lazy am i *tongue*
no need to get cold, wet, and cut hands in the scrappy.lol
