Home > Help Needed / General Tech Chat > Identify a gearbox
Neil8p
Member #: 65
South Yorkshire
Is there a quick, but surefire way to identify an mpi gearbox?
Thanks
(PS, Searched but not found anthing other then difference between A and A+)
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
rad mounting bracket missing *wink*
Usually had a red sticker on the diff housing with 2.7 MPI on it...
Neil8p
Member #: 65
South Yorkshire
Really?! lol
i was going to suggest some thing similar regards the FD numbers on the diff case.
Mines got one on it *wink*
Yes the ones I have seen have a sticker on diff housing.
The other common feature is that all the layshafts and gears seem to be made out of a special type of grey fudge.
Edited by Tom Fenton on 23rd Jul, 2007.
fab
Member #: 100
Paris\' suburb
was not laughing , the stickers usually's missing, that's how I identified mine , it had the little cooling bracket unstead of the rad one,
if the stick missing and it haven't the bracket , then count the teeth, youy'll find S ratio ( approximativaly)
nbooth660
Member #: 1234
The 1st motion gear has 18 teeth and not 17 (As Fab says like an S box). Crown wheel will have 58 teeth and pinion will have 21 to give 2.76 FD.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=159190
