| Home > Help Needed / General Tech Chat > valve settings | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
26th Jul, 2007 at 10:14:41am
I did a search and couldn't find the answer cos its proberly easy but reading the haynes, i find it really confusing. Could someone explain to me simple how to set the valve clearances, and would 40 and 30 make much diffcence.
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
26th Jul, 2007 at 10:19:55am
if you mean the clearance between the rockers and valve guides it should be 12thou - easy done, 13mm spanner, flate blade driver and feeler guages. if i'm on the wrong subject it was a late night last night lol On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
26th Jul, 2007 at 11:17:43am
there are types of feeler gauge, metric and imperial, imperial ones you should set the tappets to 12-18 thou depending on what cam and rockers are used, metric ones something like 30 (.3 mm)
26th Jul, 2007 at 10:56:48pm
nearly under stand when you say down spring conpletely compressed
27th Jul, 2007 at 06:42:15am
