| Home > Help Needed / General Tech Chat > Water Pump/ Head Help | |||||||
108 Posts Member #: 654 Advanced Member |
26th Jul, 2007 at 09:04:31pm
Hi just reassembling my turbo engine after its rebuild (never been fitted) on my old mni engine there was a take-off from the water pump going directly up into the head, why is this? and do I need to do anything about it?
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
26th Jul, 2007 at 09:20:59pm
That would be for your bypass hose. Back once again like a renegade master |
26th Jul, 2007 at 09:25:59pm
sorry if it sounds a bit basic but do I need it? and why does the mini have one and not the metty turbo
26th Jul, 2007 at 09:34:53pm
You dont need it no, but with the pump and the head you are using, sounds like you need 1.
26th Jul, 2007 at 09:45:52pm
Sorry im explaining wrong, I have a complete metro turbo engine with no bypass hose on the head or the pump, but my old engine had one on both, I assume this was just some differance in the cooling system?
26th Jul, 2007 at 09:47:13pm
26th Jul, 2007 at 10:24:47pm
thanks for the reply bat, spot on, just been cleanling and apinting so needed to know which one I should use , not that I had much choice with the head and all but cheers guys! |
26th Jul, 2007 at 10:56:07pm
kav, as bat says but...... if your fitting a water pump to do away with the bypass hose
26th Jul, 2007 at 11:00:02pm
ah rite, how come the metty turbo didnt have this as standard? was there some reason, or is it just considered a better system on the later cars?
26th Jul, 2007 at 11:42:05pm
they learned a little,
27th Jul, 2007 at 08:06:28am
as Benross said, you do still need flow through the engine untill the thermostat opens. this can be done in 3 ways
27th Jul, 2007 at 10:16:34am
option no 3 sounds the easiest but My mini sandwich plate has a heater take-off as well, is there a differance?
