Home > Help Needed / General Tech Chat > Gaskets
kav
Member #: 654
Hi, ive been searching but havent come up with much so here goes, could someone please tell me where I need to use gaskets and where I need to use sealent (is RTV ok?) My gearbox uses bolts not studs, any help would be good,
Cheers, Kav
stefaz
Member #: 1656
stoke-on-trent
you can buy complete gasket sets mate and they tend to be pretty obvious as to where they fit
kav
Member #: 654
Yer I know, I've got one mate cheers, I was just after knowing if my engine used gaskets all round as some of them use sealent instead.
please search again its been coverd before!
Basically it's whatever you took off, you put back on.
It's only the diff housing to main casing that may have had sealant, everything else has a gasket.
kav
Member #: 654
Oh so did the gearbox to block always use a gasket and no sealent then?
yes, but use some wellseal on that join, you'll not be sorry *smiley*
kav
Member #: 654
lol ok cheers
kav
Member #: 654
Hi is this the only part of the gearbox that uses sealent instead of gaskets, regardless of year? e.g. is there always a gasket between the gearbox casing and the block?
Yes always.
Th only thing that DIFFers *laughing* is the gaskets on the diff. Some had them some didn't!
danboy
Member #: 1381
Wellseal rules, silicon is shite unless used to perfection.
Regards
Dave
Edited by danboy on 27th Jul, 2007.
i agree dave, silicon does have its uses *smiley*
hmm, i was considering going sans box/block gasket as the s/c gears seem to mesh beetter without. i figured the less slop the less chatter
a very reputable engine builder said it would be fine with sealant...
On 27th of Jul, 2007 at 10:24pm danboy said:
Wellseal rules,
Wahoo after months and months banging on about it some other people are saying the same as me!
Ive been oil leak free for almost 2 years-and i used hylomar
danboy
Member #: 1381
Tom, I have been using Wellseal for many years and find it's the best. Blue Hylomar went out with the Arc.
I have done a good few Lotus Twin Cam motors over the last few years and find it's the only sealant thet will keep them reasonably oil tight. Like the Mini engine it's pretty old hat and a combination of different materials but Wellseal does the best job. Just as an after thought do you also use Graphogen as an assembly lubricant?
I have found this to be another excellent Product.
Regards
Dave
yup, graphogen and wellseal i use as its stuff we use at work *wink*
although one thing to mention, wellseal is nasty stuff. we have to ship it seperately to all the other sealants in special packaging etc.
i dont think its damaging to the skin etc, just causes havoc if released into soils etc.
I do indeed use both Dave, passed on to me about 15 years ago by a good friend of my fathers who used to own a machine shop, they were the only products he would sell, I still use both religiously.
