Home > Help Needed / General Tech Chat > Quick tank Q? Outlet smaller than pump inlet?
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
Just hit a wee bit of a snag and cant work it out. The outlet on my fuel tank is smaller than the inlet on the metty fuel pump? How do i get around this?
Any help much appreciated.
James.
MarkGTT
Member #: 1194
Shropshire.
Think i just used 8mm ID hose, its a bitch to get on the pump tho.. or you could use a fuel filter with different size inlet and outlet.
Really you need a bigger pipe fitting into the tank, otherwise you could have fuelling problems.
MarkGTT
Member #: 1194
Shropshire.
im sure mine was 8mm?
You may get away with it, but the inlet on the pump is 10mm for a reason *wink*
Also on the standard pick up pipe is a small filter which adds to the restriction.
Edited by Bat on 29th Jul, 2007.
hammoj28turbo
Member #: 1502
Ahhh, Hmmm. Erm, think i might try get a filter with a smaller inlet and bigger outlet to make it fit or i could try get the 8mm hose on. Bugger. Dont really wanna have to make the tank outlet bigger.
