| Home > Help Needed / General Tech Chat > Suddenly running rich.... | |||||||
123 Posts Member #: 1234 Advanced Member Chester |
29th Jul, 2007 at 10:00:56pm
Just started my turbo mini after a few months sat idle and it went first time. Warmed it through, shut it down and locked the house door to get some fuel. Started it up again and it started to run rough. It got worse and wouldn't tick over and eventually stalled. Would not restart and when I checked the plugs they were soaked with fuel.
29th Jul, 2007 at 10:07:04pm
29th Jul, 2007 at 10:19:48pm
New choke seals were in my kit. Got it from Avonbar and he said everything was in it (bushes for butterfly spindle and all).
29th Jul, 2007 at 10:21:23pm
whip the dashpot off and turn the ignition on so the pump kicks in, if there's fuel coming up the jet then the needle valve is fucked/jammed open.
29th Jul, 2007 at 10:23:16pm
29th Jul, 2007 at 10:25:42pm
If I let mine warm up like that, quite often it will foul a plug or 2..
29th Jul, 2007 at 10:27:58pm
I checked the fuel pressure regulator and it seems fine. No splits etc. Not checked the pressure though.
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
29th Jul, 2007 at 10:31:54pm
my moneys on the neelde valve stuck open had it on mine "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
29th Jul, 2007 at 11:28:30pm
Ditto Nogin
30th Jul, 2007 at 06:49:34am
yep happen to me after i filled up at morrisons bit inbarrasing.
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
30th Jul, 2007 at 12:00:07pm
yea id say needle valve too. mine was fine one day then later on that day it went. as quick as that. do as some else said in topic take dash pot off. |
30th Jul, 2007 at 04:49:50pm
oh buy the way mine is shagged again as it kept flooding at the rollers, so need another one from burlen always looking for them bigger bunches of bannanas |
31st Jul, 2007 at 09:28:51pm
Spot on fellas. Just unstuck mine and it works fine.
31st Jul, 2007 at 10:53:30pm
I've had this problem in the past.
