| Home > Help Needed / General Tech Chat > Timing | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
4th Aug, 2007 at 10:47:03pm
Not getting any fuel through to plugs! I put it down to the timing. Can the timing be out, if you have both dots lined up on the cogs, and when you put the cover on the line on pully lines up with the mark on the case? swoped carbs anyone else any thought why no fuel? thanks |
5th Aug, 2007 at 07:35:11am
I think you would still get fuel through to the cylinders even if the timing was way out..
5th Aug, 2007 at 09:58:41am
the cam timing you have set is a ball park figure for standard engines
5th Aug, 2007 at 11:44:43am
is there fuel in the tank?
5th Aug, 2007 at 07:12:01pm
Def sounds like fuelling problem On 19th Jan, 2010 wil_h said:
6th Aug, 2007 at 10:35:37pm
Its a standard 998 i'm tryin to get going and it has not got a pump and fuel triged off the cam i think. So thats why was thinking the timing has to be spot on any thoughts now on this cheers |
6th Aug, 2007 at 10:42:59pm
7th Aug, 2007 at 10:26:55am
Cheers bat not constant but every so often. Any thought on the prob? |
7th Aug, 2007 at 07:18:57pm
8th Aug, 2007 at 12:51:27am
engine i've never had running but it all looks genuie and i couldn't imagine the clearance being wrong but i will check. One of the carbs i swoped was a 1275 carb would that be anything to do with it? Headache minis at the moment lol. |
8th Aug, 2007 at 06:16:19pm
