| Home > FAQ / Knowledge > New Style Quaife ATB's | |||||||
10th Aug, 2007 at 01:00:29am
Ok Heres my little guide on fitting a new style quaife into your mini, its very simple:
Edited by Nic on 11th Nov, 2007. |
10th Aug, 2007 at 09:18:17am
Excellent guide nic, bit stuck on step 3 and hands are now very sore.
-MINI CLUBMAN 1380 TURBO- |
10th Aug, 2007 at 09:20:21am
good stuff nic Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Aug, 2007 at 09:40:51am
i think one of those will be on my winter shopping list!! |
10th Aug, 2007 at 09:48:06am
On 10th of Aug, 2007 at 01:00am Nic said:
Calver states that it cuts the drive to the wheel on the ground if the car jumps .. Can you point me to this article. As this appears to be bollocks. Early ATBs had no preload so if one wheel lost all traction then the wheel in the air got all the drive (just like an open diff). Modren ATBs have preload so the wheel left on the ground will alwas have some drive. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
10th Aug, 2007 at 12:44:23pm
Good stuff, one thing though, and not sure if this applies to the quaife, but dont you shim the 'wrong' side of the diff with LSDs?
809 Posts Member #: 224 Post Whore Katy TEXAS |
10th Aug, 2007 at 01:20:10pm
Great stuff Nic, like alex said,
1425 Posts Member #: 690 Post Whore Norfolk |
10th Aug, 2007 at 01:31:55pm
good article Nic - mine went in with the same ease - and grinding of cover!!
If Carling made Mini engines
10th Aug, 2007 at 04:37:25pm
On 10th of Aug, 2007 at 12:44pm joeybaby83 said:
Good stuff, one thing though, and not sure if this applies to the quaife, but dont you shim the 'wrong' side of the diff with LSDs? I thought there was something about that, this may also go some way to explaining why my potjoints are 4mm to the one side... Heres Calvers article http://www.minispares.com/Article.aspx?aid=194 Keep clapping tone, itll go eventually The old diff has already been requested Edited by Nic on 10th Aug, 2007. |
10th Aug, 2007 at 04:40:57pm
No problem BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
10th Aug, 2007 at 08:03:38pm
My LSD is shimmed to the "wrong side". I think this applies to all LSD's ? |
14th Aug, 2007 at 12:00:28am
Step 12. Tighten ball joints before driving. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Aug, 2007 at 12:47:40am
Matty=BAC
20th Aug, 2007 at 02:34:26am
So, how about an update on if you feel this consituted anything / nothing towards a sub 13-sec 1/4...
20th Aug, 2007 at 08:42:26am
I noticed that all of Nics times were consistantly better, by about 0.3 - 0.4 seconds, only Nic can determine if its the diff or not though! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th Aug, 2007 at 11:41:56am
super wright up Nic,
20th Aug, 2007 at 04:58:40pm
It contributed nothing at all, i wouldnt recommend one.....ahem
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
24th Aug, 2007 at 09:37:30am
Don't like calvers article. He bangs on about the trannex being the best diff in the world and then slates the salisbury due to its archaic design STOLEN STRAIGHT OFF SALISBURY. Not impressed, however I do want an LSD and now my 4 pin is scrap, I'm facing the same choice. I would probably go for a trannex though. Bugger off, I'm getting there. |
24th Aug, 2007 at 09:55:01am
24th Aug, 2007 at 11:13:18am
It's got a load of slop in it, I haven't taken it to bits yet. Just observing it by holding the crownwheel in the case and tweaking one pot joint. My diff bearings are the most worn I have ever seen any. I'll pull it out at some point but am looking at getting the other engine back in first. Bugger off, I'm getting there. |
11th Nov, 2007 at 10:28:26pm
Another minor f-up by me.
Edited by Nic on 19th Nov, 2007. |
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
23rd Jan, 2008 at 09:00:45pm
would a 2.76:1 crownwheel fit this? I heard they changed the design to accept a higher ratio than before
24th Jan, 2008 at 07:50:50pm
Should do,
24th Jan, 2008 at 08:02:06pm
yeah id be running 10's. thanks for the gear speeds, it doesnt sounds too bad
