Home > Help Needed / General Tech Chat > Compression question
Turbo Rich
Member #: 551
Ashington W.Sussex
Hi all
I know my cylinder head has had additional work carried out on it to reduce compression and so have the pistons. However this work was carried out many years ago and I don't remember how much of the material was removed. Is there a way I can roughly work out the compression ratio if I don't know this information?? Will a compression tester help to give an idea and if so is there a guide to show that eg 10psi = 9.4:1
Hope this makes sense!
Rich
Brocky
Member #: 224
Katy TEXAS
I noticed when I did a compression test on my standard 1275 turbo engine it gave readings around 12 bar
when I recently did a compression test on my new engine with 8.4 cr (28cc with standard +40 pistons), it gave readings of 10 bar per cylinder.
I have changed to an MG Na cam as well though so this may probably effect it to. but I think when my new engine had a standard head on with MG cam it gave readings near 12 bar also.
So I reckon you could say 11 bar may give a cr of 8.9 (8.4+9.4/2) if the cam isn't to wild ?
The only real way to knpw is to burrett the chambers and pistons etc
Hope this helps.
Edited by Brocky on 17th Sep, 2007.
stefaz
Member #: 1656
stoke-on-trent
burette, cd and oil to measure the size of the chambers in the head, then alex's compression calculator is very useful
http://www.afracing.com/CR.xls
Turbo Rich
Member #: 551
Ashington W.Sussex
ok thanks for info guys!
Pressure redings do alter with the cam profile, the wilder the cam the lower the pressure. Saying that most turbo builds have a conservative profile cam, so it shouldnt change that much.
As a comparison, my 1400 with a calculated 11.5:1 compression ratio and a kent 274 cam pushes 18 bar on the gauge!! lol it nearly maxes out the gauge *laughing*
Only real way to determine compression ratio is to physicaly measure everthing, then work out the static and the dynamic compretion ratios.
heed Mini Sprocket advice its spot on !!! *wink*
