| Home > Help Needed / General Tech Chat > fuel guage? | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
24th Sep, 2007 at 10:03:09pm
24th Sep, 2007 at 10:19:06pm
could it be working? if the tank is empty, i would expect it to do nothing! :)
24th Sep, 2007 at 10:51:17pm
new tank sender required dan
24th Sep, 2007 at 11:04:10pm
Could it be something to do with a voltage stabaliser? The reason I say this is because I have the same problem.
24th Sep, 2007 at 11:21:41pm
25th Sep, 2007 at 06:15:04pm
just done a couple of quick checks and it still does the same thing, if i just connect the 2 wires together it goes right to the top as well...
25th Sep, 2007 at 06:21:23pm
There are two connections on the sender. One is spot welded to the sender body and is an earth, one of the wires coming to it should be black, this is the earth. Check with a meter it is, then connect it. The other connection is a variable resistor, this will have a white nylon circular "bush" where the connection meets the sender body, the other wire goes to this, should be green/black.
25th Sep, 2007 at 07:17:48pm
29th Sep, 2007 at 07:32:46pm
right then i will try that, i cant beleive 2 tanks in a row with the same problem... trust me lol.
30th Sep, 2007 at 10:39:48pm
Is this the SPI tank you had off me Dan? As I know the fuel sender in that worked, as it was wired into my car and worked OK.
1st Oct, 2007 at 09:20:28pm
yes tom that one, i havent had time to check the resistance between the 2 terminals yet tho.. |
