| Home > Help Needed / General Tech Chat > allegro engine/box (gear ratios) | |||||||
9th Oct, 2007 at 12:46:52pm
hi, i bought an allegro engine/box for a mini. does anyone know if the gear ratios in the box wil be too low for use in a mini? some random guy has emailed me asking to have the gearbox as the top end will only be 50mph in a mini,then asking to buy the box. seemes a stupid claim to me, thought id check though. |
9th Oct, 2007 at 01:05:41pm
pretty sure the allegro's do have a high final drive in them, 3.7 or 3.9 maybe? On 20th Oct, 2015 Tom Fenton said:
9th Oct, 2007 at 01:08:24pm
if I recall right the 1100 had a 4.1 final drive and the 1275 had a 3.9 |
9th Oct, 2007 at 01:16:32pm
Can you count the teeth? On 28th Aug, 2011 Kean said:
9th Oct, 2007 at 01:16:48pm
Don't think there ever was an A-series with anything lower than 3.9 fitted.
9th Oct, 2007 at 01:18:05pm
good for acceleration though? |
9th Oct, 2007 at 01:20:44pm
4.somthing rings a bell with me,
9th Oct, 2007 at 01:42:31pm
I once had a 3.9 diff in my road mini clubman estate, it was by accident rather than on purpose, top speed about 75mph....
9th Oct, 2007 at 02:00:48pm
Vegard is correct again:) |
9th Oct, 2007 at 02:35:20pm
NOOOOOO! lol On 28th Aug, 2011 Kean said:
9th Oct, 2007 at 04:59:42pm
9th Oct, 2007 at 05:11:24pm
all you need is some 14" wheels and you'll be fine |
9th Oct, 2007 at 05:22:03pm
try this link
9th Oct, 2007 at 09:40:32pm
its the diff ratio rather then the ratios of the gearset though? |
9th Oct, 2007 at 09:51:42pm
Yes. all the standard gearboxes are direct drive 4th.
10th Oct, 2007 at 05:27:59pm
no good on 13' wheels then? not a problem to change a diff anyway.. |
10th Oct, 2007 at 06:05:04pm
it will be fine on 13's if you want acceleration at the expense of top end speed. If you are looking for something a bit more friendly for motorways etc then change the diff for something higher.
9th Oct, 2008 at 11:34:31pm
3.627 2.172 1.412 1.00 3.444 Mini 1000 1967
10th Oct, 2008 at 08:26:07am
Acceleration with a 3,9 and std gearbox will NOT be good. The reason is that you empty 1st so early. I bet 0-60 is faster in 2nd with a little clutch slip. On 13th Jul, 2012 Ben H said:
10th Oct, 2008 at 09:34:23am
agreed if you are accelerating form a standing start but on the road, most of the driving will be in 3rd & 4th
On 10th Oct, 2008 Vegard said:
Acceleration with a 3,9 and std gearbox will NOT be good. The reason is that you empty 1st so early. I bet 0-60 is faster in 2nd with a little clutch slip. |
