Home > Technical Chat > t2.5 turb
rhino-force
Member #: 2000
northampton
Hi there could anyone tell me whats involved in fitting one of these. Do i need to cut the bulk head? where can i get an adaptor plate etc etc.
Thanks
if you use an adaptor plate then you need the same mods to the bulkhead as a T3.
you can however use the mirage manifolds and use a t25 like me*smiley*
rhino-force
Member #: 2000
northampton
Is this the only company that makes these and did you have your turbo overalled and how much and who by. Also am i right in saying these turbo's are the rs turbo escorts and renualt 5 turbo's.
rhino-force
Member #: 2000
northampton
Edited by rhino-force on 16th Oct, 2007.
rhino-force
Member #: 2000
northampton
nope, a R5 uses a T2, a escort a T3
mirage are the only real people supplying the manifolds yes.
I bought a second hand turbo, then fitted a brand new core to it myself.
rhino-force
Member #: 2000
northampton
Oh i was under the influence that the fiesta and escort rs had the t25.
danboy
Member #: 1381
I am under the influence at the moment as well.
Regards
dave
rhino-force
Member #: 2000
northampton
I see your right. The escort has the t3 and the fiesta the t2. I'm new to the mini sceen let alone turbo'ing one.
Thanks
The Fiesta T2 will not fit the Mirage manifold as it has the wrong stud pattern.
dn89mini
Member #: 1506
Cheshire
Iain, What was your T25 from?
Edited by dn89mini on 17th Oct, 2007.
Check out the (slow) progress at.......
http://www.turbominis.co.uk/dn89mini
