Home > Help Needed / General Tech Chat > Megajolt trigger wheels etc.
Richie
Member #: 628
ok, how many teeth should the trigger wheel have, mine has 36 teeth (thats counting the tips, not the grooves), and how does the VR sensor know when it is TDC @ no.1 again, does it just count the gaps, or should one groove be larger than the rest ? here is my trigger wheel.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
its called a 36-1, 36 teeth with one missing to let the ecu know where is TDC.
yours doesnt look to have this done. has it been used before?
like this *smiley*
Richie
Member #: 628
nope, so i need to cut another tooth ? or is mine junk ?
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Yes just chop out the tooth at TDC, should be the one above the keyway, the mount sensor 90 degrees before TDC, job done. *wink*
Richie
Member #: 628
Cheers Bat, so when number 1 is at tdc which ever tooth is at the top which as you say should be the one above the key way ?
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
yep thats right,
the sensor then mounts 90deg befor this, 9 oclock looking at the front of the pully, or at the front below the rad.
Richie
Member #: 628
Right think i understand it hehehehe.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
