Home > General Chat > what would you want for your mini (electric wise)
Richie
Member #: 628
ok just thinking is there anything that people wish they had for their turbo project which is mega bucks in the shops or just plain not available ? just doing a bit market research....for those that will be supplying the humour replies, for every humour reply u must provide one serious one *wink*
is there anything that would help weather it be on a daily driver, 1/4 mile'r, or circuit car ? turbo timer perhaps ? i dunno shoot at me need inspiration.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
Ben H
Member #: 184
Melton Mowbray, Pie Country
I would like an ar=ttachment to the rod shifter with a microswitch onit so I can run lower boost in first and second and higher in third and fourth.
I am sure that people have made thes in the past and I intend to get one made up, when I get chance.
http://www.twin-turbo.co.uk
What he said, I was going to try a reverse light switch in the remote housing....
evolotion
Member #: 83
Glasgow, Scotland
an electronic thermostat to turn on an electric fan, i dont need one, but sure alot of peopel on here could use one, never beea fan of the capillary type switches most kits come with and the new solid state versions are way overpriced for what is essentially a thermocouple, op-amp and a relay :)
Denis O'Brien.
i've seen the in hose controls for about
£25 evo so not expensive.
evolotion
Member #: 83
Glasgow, Scotland
to be fair i seen them for more than that, but you (well richie) could still knock them up for a tenner delievered and still make a nice profit *wink*
Denis O'Brien.
danboy
Member #: 1381
Don't know how complex you want to get but some inexpensive datalogging would be good.
Say Rpm, Map, 2x Air temp (manifold and pre intercooler), water temp, etc. etc.
Regards
Dave
Data logger, tracking control.
Tracking control??
I meant traction control, dam auto spelling correction.
Richie
Member #: 628
tracs system for a mini Hmmmmm.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
On 21st of Oct, 2007 at 09:19pm Tom Fenton said:
Tracking control??
No more crabbing ever!!!
Richie
Member #: 628
it would be Ni-On impossible the brakes etc would need wheel speed sensors, remote opperation not to mention some way of bleeding the curley wurleys away from the wheels on acceleration possibly through the transmition somehow, iam not sure how it works, other than computers transfering the power from wheel to wheel.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
A basic system could work with spark cut and a speed sensor on a non driven wheel....
Badger
Member #: 1488
Was gonna say, surely a system could be arranged where input is taken from a driven wheel and a non driven wheel to deduce when traction is broken. That could then trigger something... say a secondary map on Megajolt 2 designed to reduce power, some kind of override on the throttle or maybe some kind of boost control. Or even better give the driver a gert big electric shock to make him lighten up!
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
barkiboi
Member #: 591
Rugeley, Midlands, England
Wouldnt minid building a mini that is possible to run an anti lag system, apparently they produce huge amounts of boost even with the butterfly cracked open.
a blow up doll with a large electric pump ...lol
AEM lambda gauge is on my next list
How about a K Type Thermocouple amplifier that would give a 0-5v signal to drive a gauge.
This could be a very cheap way of monitoring Air/Fuel Ratio
I've been searching the net for one this morning and although Magneti Marelli do one, they have a £50 minimum order value.
