Home > FAQ / Knowledge > witch needle?
racemini
Member #: 1359
Belgium
hello
my needle has been numberd as followd "1062" and i cant find this nowhere ,can somebody say what needle i need for my carb ,its a hif44 on an metro turbo engine from the year 1982
thanks
Is the engine standard or modified?
A standard needle will be available from burlen fuel systems.
Avonbar do a high boost needle for upto 10psi.
If the needle is worn, replace the jet too!
racemini
Member #: 1359
Belgium
the engine is standard.
This where you want to go then ...
There's a choice of 2 depending on the number on the carb.
racemini
Member #: 1359
Belgium
thanks a lot
:cool:
racemini
Member #: 1359
Belgium
i dont know how tho put a picture of my mini here but they can see also on my homepage, www.racemini.be
greetings
like this...
[img ] url [/ img]
without any spaces
racemini
Member #: 1359
Belgium
nice
