| Home > General Chat > OT - Consumer units / Building Regs | |||||||
23rd Oct, 2007 at 03:44:13pm
I'm building a detached garage next to my house, can I install the electrics my self, or have I got to get a propper leccy in todo it? I was planning on fitting a fresh consumer unit into the garage.
23rd Oct, 2007 at 03:47:01pm
I'm fairly sure you have to get someone part P qualified to sign it off, so you can do it yourself, but you will have to get someone else in to test and certificate it.
23rd Oct, 2007 at 03:54:07pm
Jim
23rd Oct, 2007 at 04:19:22pm
if your changing the consumer unit or installing cable then it needs to be installed and tested by a sparks
Edited by Turbo Shed on 23rd Oct, 2007. |
23rd Oct, 2007 at 04:25:51pm
23rd Oct, 2007 at 04:42:34pm
since you could have bodged the new cable under the floor with connector blocks and car speaker wire, they will not normaly certificate other peoples work. |
23rd Oct, 2007 at 04:51:11pm
You could run the wires yourself, fit all the socket boxes, lights, consumer unit etc...and leave the final connections to a qualified sparky.
23rd Oct, 2007 at 05:00:39pm
I was under the impression you could DIY as long as the you go through the correct motions with the Building Inspector, ie inspections etc as with the build process. |
23rd Oct, 2007 at 05:05:27pm
This makes it (slightly) clearer:
23rd Oct, 2007 at 05:12:54pm
it all comes down to the 'competent person' description.
23rd Oct, 2007 at 05:27:06pm
the problem is that if the DIY person makes a bodge that is hidden then a sparks issues a ticket then the sparks is responsible for the bodge and potential fire etc
23rd Oct, 2007 at 06:05:42pm
seems fair i was sure there would have been some differance between the certification. So if all the wiring was exposed, then potentially the whole of the installation can be traced and certified?
23rd Oct, 2007 at 06:26:32pm
As said above, under new part P regulations, all new circuits must be tested by a Part P registered company, and the certificate logged with the building authority.
Edited by Kean on 23rd Oct, 2007. |
23rd Oct, 2007 at 06:31:55pm
So how would you go on fitting a new consumer unit to replace an existing one? As this is not a new circuit, so does it require testing afterwards?
23rd Oct, 2007 at 06:48:08pm
When changing a consumer unit, you should carry out a perodic inspection and test on all the circuits from that board. |
23rd Oct, 2007 at 07:07:04pm
Basically as already mentiond all work should be carried out by a competent person. This does not mean that you have to have any qualifications to do the job.
http://www.twin-turbo.co.uk
24th Oct, 2007 at 08:05:41am
Plus you've had you're house longer than the regs Tom |
24th Oct, 2007 at 09:50:03am
..and new colour wire was available for at least 6 months (if not longer) before the regs changed so 'in theory' a house could've been re-wired, in new colours, and not need to be Part P certified.
24th Oct, 2007 at 06:56:00pm
Think its same kind of rules as Corgi engineers at work. Don't think they can pass other peoples work. Abit of a monoply really. On 19th Jan, 2010 wil_h said:
24th Oct, 2007 at 09:15:21pm
Nope it is not like that at all. Anybody trained can check a circuit regardless of who installed it. http://www.twin-turbo.co.uk
26th Oct, 2007 at 09:48:53am
Hmm.. from the DIYNot.com website I posted earlier:
