| Home > Help Needed / General Tech Chat > strange running problem? | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
29th Oct, 2007 at 09:26:03pm
sorry this might go on a bit but all information could help determain the problem...
29th Oct, 2007 at 10:07:42pm
yes go for the reg dan ther may be a pin hole in the diaphram
29th Oct, 2007 at 10:13:11pm
Hes alive!!! woo
29th Oct, 2007 at 11:24:53pm
On 29th of Oct, 2007 at 10:13pm Nic said:
Hes alive!!! woo I thought robh was a psycho murderer ??????????????????????????????
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
30th Oct, 2007 at 12:04:24am
Lol at nic,
Back once again like a renegade master |
30th Oct, 2007 at 12:06:33am
i'm thinking amp on the dizzy.
30th Oct, 2007 at 04:36:33am
or could just be fuel leaking past the float needle causing it to flood hence why it runs ok with out the pump on always looking for them bigger bunches of bannanas |
30th Oct, 2007 at 09:34:34am
30th Oct, 2007 at 10:26:54pm
think there is more smoke bat but its always dark when i drive it now so i cant really see what colour..
31st Oct, 2007 at 12:14:27am
dan pull the reg and strip it, give it the once over buddy theres nothing to them
1st Nov, 2007 at 09:15:53pm
i need the car every day tho and if its that thats knackerd i will want to fix it while its out.. id does still run atm, but does anout 30 miles to a tenner. lol
1st Nov, 2007 at 09:20:10pm
2nd Nov, 2007 at 04:28:58pm
tack off dash pot then switch ign on, any fuel coming out of the main jet means fuel getting past needle valve.
4th Nov, 2007 at 01:55:25pm
bat why will it cost the engine?? what am i missing just because its running too rich?
4th Nov, 2007 at 01:59:08pm
If it runs rich for too long it will wash the lubricating oil off the bores, and then the rings will wear and not seal so well, hence you'll lose compression.....
