| Home > Help Needed / General Tech Chat > Cam chain or belt | |||||||
![]() 214 Posts Member #: 1574 Senior Member Malta |
1st Nov, 2007 at 09:16:41am
I know there have been a few posts on this subject but some are a few years old now.
1st Nov, 2007 at 09:33:20am
The belt won't allow a more accurate setup. Just tak into conideration that a new chain will strech 1-2 degrees. I like chains, everyone owning a Vauxhall Ecotec engine will agree. However, the belt possibly saved my crank and rods once, as a follower cracked, and jammed my camshaft. God knows what would've happened if the belt hadn't broken. On 13th Jul, 2012 Ben H said:
1st Nov, 2007 at 09:55:17am
On the A series does anyone know if the valves would hit the pistons if the belt snapped?
1st Nov, 2007 at 09:58:45am
Have you considered the Kent "silent chain" setup? The chain is made up from multiple plates, not like the conventional type with plates and rollers. Reputed not to stretch? And also quite a lot quieter than the normal chain. I'm running this on my car anyhow.
1st Nov, 2007 at 11:01:56am
i got told by an average/poor mini specialist that the Kent chain wore out really quick and that they would never fit another one. personally i take everything they say with a pinch of salt but it does make you think twice. |
1st Nov, 2007 at 11:18:21am
Which alternative were they selling then? |
1st Nov, 2007 at 11:19:13am
Tom, do you have a part number for the silent chain setup? I'll take a look at that.
1st Nov, 2007 at 11:38:51am
I don't I'm afraid, however regarding the wear issue I can tell you that it has done over 20k in my road mini a few years ago, and was like new when I took it out of that shagged engine, it is now in my turbo engine. Min-its I believe still sell it (that is where I bought mine, 10 years ago now), listed as "high velocity silent chain" kit.
1st Nov, 2007 at 11:56:32am
Thanks Tom - I'll have a look at it on their website.
1st Nov, 2007 at 12:59:18pm
Nic the answer is yes or no,
On 1st of Nov, 2007 at 09:55am Nic said:
On the A series does anyone know if the valves would hit the pistons if the belt snapped? Presumably it would as people on here have smacked valves on the pistons when theyve siezed in the guides On 28th Aug, 2011 Kean said:
1st Nov, 2007 at 02:15:57pm
They may have modified it now, but there were some dimensional problems with the MS lightened steel set-up that caused them to be misaligned the wrong way for shimming to correct (ie the crank sprocket was already further out than the cam sprocket).
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
1st Nov, 2007 at 06:12:44pm
i recently had a rotoslide belt ( not broken but stripped .. even after extensive and meticulous autosy i can't frigin find a cause )die after a full engine build and 35 miles tops..
Edited by Sir Yun on 1st Nov, 2007. That sir, is not rust, it is the progressive mass reduction system
1st Nov, 2007 at 08:48:45pm
2nd Nov, 2007 at 09:02:45am
My Cam is a 266. By the looks of the comments on this post it looks to me like a decent duplex will be fine for my purposes. Thanks to all
