| Home > General Chat > Garrett GT15 oil control - Tel? | |||||||
141 Posts Member #: 954 Advanced Member Fort Collins Colorado USA |
2nd Nov, 2007 at 03:46:47pm
For awhile I thought I had scavenging pump problems on the drain, but now have concluded that too much oil pressure is getting to the turbo. Once the oil is hot, higher RPM running gives a cloud of smoke when you stop and idle. Also, there is oil in the intake pipe as well.
1275 with Back Door Turbo |
2nd Nov, 2007 at 06:32:20pm
am running a T28 (79 Trim, .86 A/R Housing) and had similar issues to yourself, going down to a 2mm(0.078 inch) restrictor, got rid of most of my prblems, only now get some smoke if i accelerate after idling for 20 mins or more. is the GT15 a ball bearing unit? im sure these can take a much smalle rrestrictor, but best google and see what you dig up. turbo 16v k-series 11.9@118.9 :)
2nd Nov, 2007 at 08:31:09pm
With my GT15 I'm not running a restrictor, best info I got was that it didn't need one but remember some other models did.. maybe the ball bearing type??
Edited by Turbo Tel on 2nd Nov, 2007. website:- http://www.terryhunt.co.uk
2nd Nov, 2007 at 08:38:24pm
Ahahhh!!!
3rd Nov, 2007 at 01:30:11am
Thanks.
Edited by fortfun on 3rd Nov, 2007. 1275 with Back Door Turbo |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
3rd Nov, 2007 at 08:29:23am
A friend had similar problems with a Turbo. It turned out to be a restrictive drain rather than excessive oil pressure/flow. |
3rd Nov, 2007 at 08:32:46am
3596 Posts Member #: 655 Post Whore Northern Ireland |
3rd Nov, 2007 at 10:16:18am
Ensure the drain is totally clear and free flowing.
3rd Nov, 2007 at 12:49:57pm
yup, i too ha a smokey turbo due to a poor drain. |
5th Nov, 2007 at 02:44:57am
Drain appears perfect. Hoses all clearly visible and no kinks. What else should I check for? Suppose I could put a pressure gauge on the oil outlet from the turbo to make sure there is no pressure, but it seems unlikely to have any pressure viewable on a gauge.
5th Nov, 2007 at 08:13:24am
6th Nov, 2007 at 12:34:34am
Hmm... Response from a turbo vendor:
6th Nov, 2007 at 07:40:58am
6th Nov, 2007 at 03:57:26pm
Apparently yes. STS now includes them with kits - apparently the change was made around the time of my purchase, but I don't seem to have one.
Edited by fortfun on 6th Nov, 2007. 1275 with Back Door Turbo |
6th Nov, 2007 at 07:51:32pm
Sourced a check valve and fittings today. Might be a few days before I get it put on. Hoping for a cure! 1275 with Back Door Turbo |
8th Nov, 2007 at 08:52:04pm
Check valve in. Drove it about 35 miles on the highway hoping to blow the oil out of intake and exhaust piping. Unfortunately the boost pipe blew off the carb hat 3/4 of the way through the trip. Stopped and reattached, tightening with a vengeance this time. Had to drive about a half mile to a mile before getting to a good spot. It was smoking again when I idled in the parking lot. I've read that having the compressor spinning but not generating boost will cause the bearings to blow out oil, so this may not be a fair test given the pipe blow. Will have to drive it awhile and see if the smoke clears. 1275 with Back Door Turbo |
8th Nov, 2007 at 09:37:41pm
Given where your turbo is located, is your scavenge pump working properly ? 9.85 @ 145mph
9th Nov, 2007 at 04:00:42am
Seems to be. Not getting smoking while rolling down the road, where oil pressure is higher than at idle. It smokes at idle. I've got an uprated alternator, and a voltmeter built into the Prologger. I turned the idle up to 950 RPM awhile back so that the alternator puts out no less than 14V because I was wondering if the scavenging pump was slowing down at idle. No change. Edited by fortfun on 9th Nov, 2007. 1275 with Back Door Turbo |
9th Nov, 2007 at 09:00:57am
9th Nov, 2007 at 06:35:43pm
Always had the smoking.
9th Nov, 2007 at 11:36:12pm
