Home > Help Needed / General Tech Chat > Radio
Zeemax Power
Member #: 393
Oulton Park
Anyone know much about radios the radio works but memory wire only reads 00.19 when swiched on. any thoughts
http://www.Zeemax.com
fortfun
Member #: 954
Fort Collins Colorado USA
What's a memory wire?
1275 with Back Door Turbo
The question seems a little strange to me. Are you measuring the voltage on the memory wire coming out of the radio, or the memory wire coming out of the car?
fortfun .. It might me a UK term, but the memory wire is a 12v permanent feed than keeps the memory alive in the radio.
Edited by Bat on 11th Nov, 2007.
codd_coupe
Member #: 1772
Leicestersheershire
The feed for the memory of a stereo needs to be a permanent feed.
In true industry standards sometimes the two feeds for the stereo are the wrong way around, which would mean that when you turn off the stereo, you loose your memory.
Check that they are fed correctly and that the "memory" feed isn't driven by the ignition.
Edited by codd_coupe on 11th Nov, 2007.
Tim Rowe
"Is est totus perfectus per fumi quod speculum"
GTM Coupe Turbo
yup, they are normally yellow and red *smiley*
diddy
Member #: 505
Stockton-on-Tees
It could be that your referring to the REM wire?? the blue one used to switch on amps or remote aerials, this would only be a small reading
Zeemax Power
Member #: 393
Oulton Park
all sorted now thanks lads! radio basicly memory i ment is a wire that tells amps when to come on. basicly read nothing when the radios off then 12v when the radios on, there for turning the amps on.. My prob was when the radio was on it still read hardly anything, but what i've done is put a switch now, and turning the amps on myself. JVC for you lol
So you mean the blue 'remote' REM lead.
If this is no good then use the red 'ignition live' not the yellow 'permanent live' (otherwise you'll have trouble starting in the morning lol)
Edited by theoneeyedlizard on 12th Nov, 2007.
