| Home > Help Needed / General Tech Chat > fuel problem? | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
11th Nov, 2007 at 03:58:55pm
Hi, trying to start my engine today (have just fitted the turbo, carb etc) and it will not start. Engine was fine before started first time, i have checked the spark, this is fine so im assuming i have a fuel problem, i have changed all the fuel lines. I am getting fuel at the carb tho? could there be a problem with my carb? i have not used it before, is there anything i can check or will i have to strip it?
11th Nov, 2007 at 04:45:40pm
Edited by Bat on 11th Nov, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
11th Nov, 2007 at 05:46:38pm
No have taken the plugs out and they are dry, must be a problem in the carb, will take it off tomorrow and check. The engine has been re-built and i have run it in without the turbo. Fitted the turbo, carb etc this weekend and now how this problem, was using a different carb when running it in so must be the problem. Cheers |
11th Nov, 2007 at 05:49:59pm
11th Nov, 2007 at 06:46:01pm
check the dashpot isnt stuck or 9.85 @ 145mph
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
17th Nov, 2007 at 03:39:27pm
gasket between carb and plenum, the hole needs putting in the gasket cant remember the term someone will be to explain more if you havent thought of this one |
17th Nov, 2007 at 09:43:02pm
To check the fuel in the carb take the dashpot off and look down into the jet, you should be able to see the fuel level a few mm down the hole, If not then the fuel is not getting in or is too low, It helps to shake the car a bit when trying to see the fuel level. Edited by Turbo Tel on 17th Nov, 2007. website:- http://www.terryhunt.co.uk
