| Home > Help Needed / General Tech Chat > bleed valve/ boost gauge | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
16th Nov, 2007 at 08:44:02pm
I have my boost gauge plumbed into the inlet manifold, however i am getting funny readings. Do i need to plumb it in between the bleed valve and actuator? |
16th Nov, 2007 at 08:47:48pm
Where abouts in the inlet manifold, and what are the funny readings?
17th Nov, 2007 at 10:00:06am
Have put the boost gauge pipe going to the servo bolt on the inlet manifold, gauge is reading 20InHg (around the opposite direction of the gauge from psi) at idle and when i drive and use the throttle it goes up to 0 and will not go any higher? |
17th Nov, 2007 at 10:23:29am
17th Nov, 2007 at 11:53:50am
Hi cheers mate, il try and get a spacer plate today, have a feeling that it already has one fitted but has been soldered up for some reason, il see if i can sort that. Thanks |
17th Nov, 2007 at 12:47:56pm
Am i right in thinking the one way valve is built into the servo bolt? i have removed this and have replaced it with a fixing that screws directly into the manifold in its place, i have then connected my boost gauge pipe to this. i am still however getting negative figures until i rev it where it goes to 0. I have not yet driven it so should it boost up when driven? |
17th Nov, 2007 at 12:54:44pm
17th Nov, 2007 at 02:17:38pm
Cheers mate jus been for a drive and its working fine, thanks for the help |
17th Nov, 2007 at 02:33:32pm
