Home > Help Needed / General Tech Chat > Alternative to the usual Heated Inlet Manifold
Anton
Member #: 764
Staffordshire
My inlet manifold does not have the option to heat it, is there any little tricks i can do to get some heat into the carb? (other than buy another manifold)
I had carb icing last night on the way back from bud666's don't fancy it again :S
on another note does a weber DCOE suffer carb icing?
Yep they'll ice up as good if not better than anything else.
I usually run some ducting pipe up from the exhaust manifold and point it at the air filter.
I also block off the cold air feed to the filter.
You could try soldering some copper pipe to the inlet manifold and run the water through that.
Edited by Bat on 17th Nov, 2007.
get hold of a turbo manifold or second........................... slightley best! N/A MG manifold
job done!
turbo hogster
Member #: 178
stowmaket suffolk
i have tried with sucsess, but in a section of pipe from heater tap of on the head then bend it round the dash pot a couple of times the plug back into heater input pipe. heats dash pot up a treat which helps with the icing.
JT
Member #: 637
Hertfordshire
how can you tell its icing up? does it just cut out when you come to a hault? or does it just cut out stright away?
My build thread..
Mine (45 DCOE) usually starts missing on light throttle. If you pull over, switch it off for a couple of mins, then restart it's fine for a bit till it ices again :(
on my dads old beetle he had some electrical jacket that put heat around the manifold
da daaaaaaaa
http://www.bigboyztoys.co.uk/index.php?pag...47482ed6d2be918
(im sure it used to be alot cheapere than that though)
Edited by Nic on 18th Nov, 2007.
mikemph
Member #: 449
Oxford
I'm sure I have a manifold kickiing about somewhere make me an offer, PM me. I will see if I can find it out one night.
