| Home > Help Needed / General Tech Chat > Probs again :( | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
19th Nov, 2007 at 10:58:05pm
Car seems to be running hot and dont know why standin any thoughts seems to be a pressure under rad cap after running. Engine so painful just been built lol. Scared of running it to be fair even though it does drop but haven't had a proper run scared of damage or should i go for it.
19th Nov, 2007 at 11:01:33pm
There will be pressure in the system once the car becomes warm
19th Nov, 2007 at 11:07:14pm
cheers nick feel better knowing that but never known a engine so hot lol |
19th Nov, 2007 at 11:08:21pm
to add to Nic excellent advice have you a 74 deg stat fitted to help things out
19th Nov, 2007 at 11:12:30pm
got a 4 core rad should be ok just was going a little bit above a 100 on my temp gauge and worryed me
19th Nov, 2007 at 11:34:45pm
tappets not realy what cam have you in ?
20th Nov, 2007 at 05:35:18am
make sure that the screws are not hitting the back of the rocker cover..
20th Nov, 2007 at 09:26:05am
thanks for the advice hogster! Running pipercross cams benross |
20th Nov, 2007 at 10:07:27am
If the engine's just been built wont it run hotter for a while until its run in? |
20th Nov, 2007 at 04:54:30pm
tappets are the worse noisy keep taking the rocker cover off and set them and still noisy |
20th Nov, 2007 at 05:36:50pm
On 20th of Nov, 2007 at 05:35am turbo hogster said:
make sure that the screws are not hitting the back of the rocker cover.. Check this? In the 13's at last!.. Just |
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
20th Nov, 2007 at 06:35:02pm
if it's just been built has it been setup? when I fired mine up the first time, the igntion timing was too retarted, so ran hot.
20th Nov, 2007 at 10:05:14pm
21st Nov, 2007 at 01:36:49am
On 20th of Nov, 2007 at 10:05pm Bat said:
That's a good point Leonard. I had my lcb glowing bright red once! ![]() that viagra is a terrible thing gav!!:$![]()
21st Nov, 2007 at 03:47:46am
whats the duration of the cam ?
22nd Nov, 2007 at 10:07:09pm
cheers for the help took the cover off again decided that the rockers are worn cos move quiet a bit. Wonder is it possible to change rockers without doing a head gasket??? |
22nd Nov, 2007 at 11:19:21pm
22nd Nov, 2007 at 11:24:35pm
23rd Nov, 2007 at 08:57:42am
On 22nd of Nov, 2007 at 10:07pm Zeemax Power said:
cheers for the help took the cover off again decided that the rockers are worn cos move quiet a bit. Wonder is it possible to change rockers without doing a head gasket??? There should be some play in them. In the 13's at last!.. Just |
24th Nov, 2007 at 10:34:38am
what u meanby this dizzy quiet down
On 20th of Nov, 2007 at 06:35pm Leonard said:
if it's just been built has it been setup? when I fired mine up the first time, the igntion timing was too retarted, so ran hot. |
