| Home > Help Needed / General Tech Chat > flywheel, starters and clutch | |||||||
23rd Nov, 2007 at 02:40:52pm
i have two engines one with a pre-ingaged starter the other doesnt. both have verto clutches but are the flywheels diffrent for each starter?? i am asking as they both look nearly identical and im still not 100% sure. i dont want to remove the fly ect for nothing please help can you use one starter on each fly or not???
23rd Nov, 2007 at 03:04:05pm
23rd Nov, 2007 at 03:35:03pm
one has 105 teeth (not pre ingaged) the other has 130 teeth (pre ingaged) so i geuss i have to swap the flys over :( Drives
23rd Nov, 2007 at 05:21:15pm
looks that way.
24th Nov, 2007 at 03:27:48pm
has anyone got any hints or tips of ways to get the flywheel off at the moment it is only me and i have tigned up the puller as much as i can on my own (as the engine is out it keeps rocking arround even with a foot on it) would i still be able to get it futher on my own or do i need to get somone to help me? Drives
24th Nov, 2007 at 04:41:25pm
24th Nov, 2007 at 05:30:08pm
the bolt isnt in there, should i put it back in and try it that way? the only thing with doing that would be it would tighten the bold back up anyway because of the friction... Drives
24th Nov, 2007 at 05:39:13pm
25th Nov, 2007 at 01:44:10am
so should i try with the bolt in? Drives
25th Nov, 2007 at 10:24:08am
yes, most pullers will fuck up the flywheel bolt thread in the crank if used without the bolt in place (suitably loosened of course)
25th Nov, 2007 at 02:39:18pm
It can help to get a good powerfull blow torch on the flywheel. On 28th Aug, 2011 Kean said:
25th Nov, 2007 at 04:51:50pm
i managed to get the fly off the blue engine on my own was a peice of piss, after 35 mins of slowly tightening the puller for the red engine i left it taped it with the breaker bar when i moved passed got passed nd it shot off the side lol so both off now :) cheers for the help Drives
