| Home > Beginners Tech > Stupid question but... | |||||||
53 Posts Member #: 2069 Advanced Member Oxfordshire |
23rd Nov, 2007 at 04:19:33pm
Where does the oil take off come from on the block to the turbo?
23rd Nov, 2007 at 04:59:57pm
correct mike
23rd Nov, 2007 at 07:01:57pm
steve doesnt the oil pickup come off the pressure switch boss lower down ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
23rd Nov, 2007 at 07:33:26pm
23rd Nov, 2007 at 08:03:48pm
yes robert,
24th Nov, 2007 at 06:25:24pm
Cheers guys |
24th Nov, 2007 at 06:37:30pm
On 23rd of Nov, 2007 at 07:33pm Bat said:
Hi, Feed the turbo from the oil pressure switch port via a tee piece. This way you're feeding the turbo with filtered oil :) Cheers, Gavin :) This isn't filtered is it? The T-piece is straight after the pump.. On 13th Jul, 2012 Ben H said:
24th Nov, 2007 at 07:08:06pm
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
24th Nov, 2007 at 07:10:27pm
So does this mean Vegard has got something wrong?????? |
24th Nov, 2007 at 07:13:17pm
24th Nov, 2007 at 08:05:22pm
surely not, maybe someone has hacked his account? "Turbo's make torque, and torque makes fun"
24th Nov, 2007 at 08:52:53pm
Lol.
25th Nov, 2007 at 01:58:04pm
On 24th of Nov, 2007 at 06:37pm Vegard said:
This isn't filtered is it? The T-piece is straight after the pump.. Vegard is actually right I believe, hence why I have my turbo oil feed connection tapped directly above the filter housing on the block. |
25th Nov, 2007 at 09:07:48pm
25th Nov, 2007 at 11:14:55pm
On 25th of Nov, 2007 at 01:58pm Turbo Phil said:
Vegard is actually right I believe Youve gone and done it now phil! I believe phil to be right though |
26th Nov, 2007 at 04:12:37am
o my god !!!!
Edited by robert on 26th Nov, 2007. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Nov, 2007 at 08:27:34am
I'm going to check on this, because i've had this debate before. If Phil Hepworth {Gp A Metro building legend} though it worthwhile tapping the oilfeed from above the filter then there must be a reason ........ |
2nd Dec, 2007 at 12:24:17pm
i cant stand the suspense phil ,whats the verdict ?? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2nd Dec, 2007 at 12:35:34pm
2nd Dec, 2007 at 01:12:27pm
Mines got a ally block that sits between filter housing & engine block that the turbo oil feed picks up from. On 19th Jan, 2010 wil_h said:
2nd Dec, 2007 at 01:13:47pm
On 2nd of Dec, 2007 at 12:24pm robert said:
i cant stand the suspense phil ,whats the verdict ?? I think they are hiding in embarassment - well at least they should be
2nd Dec, 2007 at 01:24:17pm
6th Dec, 2007 at 06:19:26pm
sister pics? "Turbo's make torque, and torque makes fun"
6th Dec, 2007 at 07:05:17pm
I agree with Gavin, Vergard is wrong, trace through the oil ways in the block and you'll see that the take off for the oil pressure gauge is feed directly from the rear oil gallery.
6th Dec, 2007 at 07:44:38pm
I've got no sister, but I could get a picture of my mother if that helps.
