Home > Wanted > Mini Pre-engaged Starter motor / bracket
I'm after the drive end bracket for a Mini starter motor. That's the alloy one on the end of the starter that fits into the flywheel housing. If you have a dead starter or the bracket please get in touch :)
Here's a picture of where to find the part number if your not sure it's mini or metro :) Part number is 54291741
Mine was unfortunately destroyed in an argument with a combine harvester *surprised*
Edited by Bat on 24th Nov, 2007.
minimail 01989 720 111 have a few of these on the shelf if you cant get one one here
(theyre closed mondays though)
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Do tell about the combine.
Don't know, previous owners handywork!
Wrote a 2000 Cooper Sport off...
graemec
Member #: 1424
Carnforth, Lancs
Presumably they will be different for Mini and Metro - it must be this part that determines where the solenoid sits in realtion to the mounting bolts?
Spot on Graeme, I think the metro number ends with a 9, not got it in front of me at the mo.
Fairly easy to swap the brackets over *wink*
graemec
Member #: 1424
Carnforth, Lancs
Hmm, wouldn't mind a Mini one (or two) myself then!
I had a Metro one on mine until recently. It only just clears the bodywork at the front of a round nose.
The Metro one is 90 deg in relation to the engine and the Mini one is about 45 and gives lots more clearance..
