Home > Technical Chat > seperating pistons from the con-rods?
JT
Member #: 637
Hertfordshire
hi
iv done a quick search but i couldn't find anything.
can you take the pistons off the con-rods without breacking the piston or damaging them?
the 15cc forged omega pistons i bought new from someone on ebay have standerd con-rods that im not sure i want to use as i want them lightend etc along with the crank so its smooth reving engine. and hopfully it would help it rev higher?
cheers
josh
My build thread..
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Pay someone else to do it. :)
Could try a flypress...but is it worth risking £400 worth of pistons????
On 19th Jan, 2010 wil_h said:
danboy
Member #: 1381
Josh, I have made a piece to support the Omega piston while the pin is pressed out.
You can borrow it if you want.
You will need acess to a press to do the job properly
Regards
Dave
I thought you heated the little end of the rod till it's a straw colour then they almost fall out?
danboy
Member #: 1381
Hmmmm!
Regards
Dave
I have used this with a fair bit of sucess...
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=122262
That's during assembly. How do you manage to heat the rod, and NOT the wrist pin when it's fitted?
I'll pay someone to do it. It's so easy to break them.
Anyone who has ever removed pistons from rods for me has done so with a disclaimer beforehand along the lines of "I'll do my best, but if one gets damaged hard lines".
Next question, why do you want to mess with the rods, standard ones do the job just fine, plenty of people use them with no problem, I've never known a turbo engine bust a rod as generally they don't rev all that high. More important though is the rod bolts, I use ARP personally.
i agree with tom
I was going to type all of this yeasterday, but i couldnt be muster up the energy
In a vegard stylee-Tom is right
Ive done it with 3 large cap head bolts and a vice, they were buggered pistons though! I would never do it with good ones.
Take it to a professional everytime.
JT
Member #: 637
Hertfordshire
ill leave them as they are then
cheers
josh
My build thread..
I took my rods to a professional, and thats how they did it. Welding torch with a fine tip, heat it up away you go :)
