| Home > Help Needed / General Tech Chat > LCB manifold | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
1st Dec, 2007 at 03:11:53pm
does anyone know if there is a difference between a LCB for a mini and one for a metro? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
1st Dec, 2007 at 03:16:45pm
I have used mini LCB's on metros, i think they could ideally do with being about 3/8" shorter, plus the metro engines move about a fair bit as there is no top steady so the pipe can pop off if you do dump the clutch really hard. On 28th Aug, 2011 Kean said:
1st Dec, 2007 at 04:30:55pm
1st Dec, 2007 at 04:35:19pm
does it exit at a slightly different angle? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
1st Dec, 2007 at 04:43:26pm
maybe i have that the wrong way then,
1st Dec, 2007 at 04:50:52pm
the problem that i have is that i brought a 3 into 1 type manifold for the mrs car and the angle that it exits is completely different to the one that i took off, rather than pointing straight back its slightly to the passenger side, which doesn't allow the link pipe to fit onto it as it should...the exhaust would end up exiting in front of the passenger side rear wheel..
1st Dec, 2007 at 05:04:02pm
1st Dec, 2007 at 05:07:31pm
a mini. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
1st Dec, 2007 at 05:12:37pm
erm dunno, not seen that before.
1st Dec, 2007 at 09:54:16pm
buy the missus a metro. On 19th Jan, 2010 wil_h said:
