| Home > Help Needed / General Tech Chat > Braided fuel hose (how to cut? ) | |||||||
1st Dec, 2007 at 06:10:55pm
As title . Anybody got a good trick on how to cut it properly
1st Dec, 2007 at 06:18:17pm
1st Dec, 2007 at 06:35:35pm
forget tape and a junior hacksaw, the teeth still grip, shread and flare the ends.
1st Dec, 2007 at 06:43:16pm
I will go with joey this is what i do when making hydraulic pipes! i wish i had found the 1mm thick discs when i did the welding on my mini! |
1st Dec, 2007 at 08:43:26pm
Thanks lads il have a go with the cutting disc.
110 Posts Member #: 1657 Advanced Member wirral |
1st Dec, 2007 at 08:46:29pm
a multi tool like a dremel works a treat On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice. 10.5 psi no idea how many banannas |
2nd Dec, 2007 at 06:09:23am
1mm discs on the grinder here too.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
2nd Dec, 2007 at 11:24:47am
I'd go for the frine grindging disc, they work great.
2nd Dec, 2007 at 11:25:53am
make sure you clean out your hose when you have it all assembled it. |
365 Posts Member #: 1211 Senior Member Working up the BHP ladder. |
2nd Dec, 2007 at 11:55:33am
multi tool cutters (like the dremmel) work a treat. If you want a nice finish put a bit of heat shrink tubing over it after.
2nd Dec, 2007 at 12:12:42pm
Going to get some 1mm cutting discs tomorow and see how i go, yes am daft but hopfully not daft enough not to clean it out afterwards, shouldnt need the heatshrink as am putting fancy goodridge fittings on !. Just need to drill and tap my reg now (not looking forward to that).
2nd Dec, 2007 at 06:23:08pm
Thin cutting discs rock 9.85 @ 145mph
3rd Dec, 2007 at 07:10:07pm
Got my cutting discs today , got some of it done and just to let you no its loads better than the hacksaw.
3rd Dec, 2007 at 08:17:13pm
Or buy a set of pukka tube cutting shears. They work a treat, and you have confidence of no crud in the line.
