Home > Introduce Yourself > Newbie yet to buy a mini.
Unkle
Member #: 2118
Hi all, been nearly 20 years since I last owned a mini! - Been far too long.
So shortly (in the new year) will be looking for any basic spec mini that body isn't shot.
Plan a respray in Orange and a turbo installation for light road and track use.
Any advice gratefully received! Guessing i'll need around 150bhp to get reasonable track times/fun.
andy
Welcome to TM! :)
Have a browse around you'll find plenty of info to help you in your project *wink*
Unkle
Member #: 2118
Thanks for the welcome.........I'll be browsing around now and apologise in advance for any stupid questions!
last time I worked on a mini it was a 1974 and the car was only about 13 years old!*wink**wink* so turbo's are new to me (in mini's) but seems the sensible path to decent power.
I've come to the same conclusion.
I'm currently running an N/A 1380, but ditching that for a standard 1275 running about 10 psi, should give the same results but a lot nicer to drive *wink*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Hello Unkle...welcome
On 19th Jan, 2010 wil_h said:
Unkle
Member #: 2118
Great minds think alike!
I was looking at the 1293 with similar amount of psi maybe a little more.
I did like the lok of Morspeed's 1293 running 17psi & around 170bhp but not sure how long that sort of engine would last! Probably as long as a tuned 1380.......
Unkle
Member #: 2118
double post
Edited by Unkle on 2nd Dec, 2007.
With good oil in it you shouldn't have to many problems.
It gets more expensive as the boost goes up as you need to spend more on the g/box, S/C drops then S/C box!
Welcome...turbo is the only way to go! *wink*
Welcome Matey!
T3Tone
Member #: 252
Sunny suffolk
Hello and welcome, good luck with the project
-MINI CLUBMAN 1380 TURBO-
