Home > Wanted > t2 excaust elbo
nut241
Member #: 2122
hi all could any one help me im lookin for a t2 excaust elbo could you help
What for?
I would guess a mini as this is a turbo mini forum. The only one that you can readily buy is the one that Mirage sell, but this comes as a kit with the manifold and would be useless without it.
What exactly are you trying to do? there are 3 main ways to fit a T2:
1)use the mirage kit (the most expensive but easiest)
2) Use the Metro manifold and make your own exhaust elbow
3) Make a completly bespoke manifold and elbow.
nut241
Member #: 2122
ive modded the manifold to fit the t2 turbo but got problems with the excaust .ive spoken to rich at mirage and he said just the elbo will work just wondered if the was any other was to do it
I'm pretty sure I've got one you can have, but as Wil says why?
nut241
Member #: 2122
hi rob is it from a reault 5 or has it been made for a mini .if so what you want for it cheers
It's the bog standard Renault 5 item, if you want it it's yours for free, just pm me your address and I'll chuck it in the post.
nut241
Member #: 2122
im new to this web site how do i pm you
Look in the top right hand corner of the persons post and you'll see PM User in grey text, click away *wink*
nut241
Member #: 2122
cheers for the help gavin
You can use the Renault 5 elbow. You need to cut it in half vertically and rotate the outer section and re-weld it. This is what i've been running for years now.
nut241
Member #: 2122
are they cast coz i cant weld cast
I believe they are, mine was welded with an ordinary MIG though.
nut241
Member #: 2122
il try it then thanks
