| Home > Help Needed / General Tech Chat > MPI Clocks | |||||||
5th Dec, 2007 at 10:42:19pm
Been eyeing up a walnut dashs on ebay, and really want a genuine rover mpi one
5th Dec, 2007 at 11:00:42pm
5th Dec, 2007 at 11:03:29pm
ah, and no, its a carb bat
5th Dec, 2007 at 11:06:25pm
At the very least you will need to wire in the rev counter, however the wires should be in place for that (at least they were on mine) the Speedo will read out as the MPIs had a 2.7 diff, but it wouldn't be a Mini if the speedo was remotely correct and I'm not sure about the temperature gauge as the temperature gauge on the MPIs gets it's feed from the ECU. Isambard Kingdom Brunel said:
5th Dec, 2007 at 11:07:14pm
5th Dec, 2007 at 11:07:21pm
right, got to get a walnut dash now, just won this:
1050 Posts Member #: 764 Post Whore Staffordshire |
5th Dec, 2007 at 11:42:36pm
anyone any idea how you conv the MPI rev counter to read normally on a coil based engine? |
6th Dec, 2007 at 12:15:00am
You cant, unless some one can figure out a way for the tacho to only read half the ignition events.
6th Dec, 2007 at 12:15:54am
6th Dec, 2007 at 08:34:49am
I bow to Sprocket's knowledge on injenction stuff but I thought there was an adjustable pot on the back of the MPi rev counter that could be tweaked to fudge the revs correct. |
6th Dec, 2007 at 04:57:07pm
On 6th of Dec, 2007 at 12:15am Sprocket said:
You cant, unless some one can figure out a way for the tacho to only read half the ignition events. Should be able to do it with a 555 no problem. Isambard Kingdom Brunel said:
6th Dec, 2007 at 05:13:28pm
On 5th of Dec, 2007 at 11:07pm joeybaby83 said:
right, got to get a walnut dash now, just won this: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWN:IT&ih=011 bargain! The seller is also selling a matching dash, might be worth seeing if he'll do you a discount on both. Isambard Kingdom Brunel said:
6th Dec, 2007 at 06:37:11pm
yes you can alter the rev counter by opening it up. inside there is a small screw that you adjust. this will give you a true reading, i have seen pics on other forums but can't find them. all the rest work ok |
6th Dec, 2007 at 07:43:42pm
Will it really adjust out 4000rpm??
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
6th Dec, 2007 at 09:50:10pm
Heres the link to ML Motorsports guide:
